I've just picked up an MX. Wanted one for a while and it seemed a fair deal. It wasn't, it's in a pretty bad state grime-wise, and it was sold-as-seen so I can't return it - and just to get this out the way, I can't justify/afford a 'proper' CLA right now and it's so battered I'm not sure it deserves it!
So before I chalk this up (down?) to experience and flog it for spares or give it to my 4 year old to use as sandpit toy (jokes!), I'd like to try and clean it a bit myself, gain some experience and maybe even be able to use it!
Some info on condition:
- Mirror foam is shot and hanging down. I've ordered replacement foams and seals.
- Practically every surface is dented, scratched, rusted or brassed.
- The Mirror locks up about half of the time, at most speeds, I've not been able to find a pattern yet. I'm pretty sure it's not the sticky foam holding it up because to get it back down again I have to either wind it again and fire, or manually take the lens off and reset the lever on the left of the Lightbox with my fingernail.
- I've taken the base off, and there is a lot of dust, greasy foam particles etc.
- I ran a short roll through and nearly all the photos seem to have only part of the frame exposed so there must be some shutter curtain sync issues I guess.
Firstly I'd like to get the gearing in the base clean (pic attached). When it comes to cleaning this area up, would it be best to dissemble the whole mechanism and clean each part, or can I maybe gently flush the gears through with alcohol, dry everything, and re-lube them with a tiny amount of light oil afterwards?
I've searched around quite a lot, and every time someone asks similar questions they answer is "get a CLA". So assuming I'm definitely
not getting a CLA, what advice would you give me?
