Are there any parts of the images in focus? If so, then it's likely a focus problem, as the others have mentioned. But if the whole image is uniformly unsharp, it could be something like the mirror bumper foam starting to disintegrate and the mirror is causing more vibration than it should. Have you looked into the mirror box to check it? If it's crumbly and/or sticky, then it's time to replace it. This is to be expected for a 40+ year old camera. It's a moderately easy DIY job, but any reasonably competent camera repair tech can do this for little money. While you're at it, check the light seals around the door and replace those if they're looking the same.
Another thought - are your lenses clean? Apologies if I'm stating the obvious, and I'm by no means trying to insult your intelligence. But you'd be amazed how many people never clean their lenses, and go around shooting with fingerprints, dust and haze all over the front elements and then blame their camera. Or if they do clean them, how few actually do it properly.
Hope this helps. Good luck finding and fixing this.
