Hi All
I just purchasesd a Pentax Super A film SLR. Has anyone found a readily available 'ever-ready' style case for this model. It has a lumpen shape so the normal kind of pentax ever-ready cases will not fit.
When I say 'ever-ready' I mean the type that covers the whole camera and lens. The top part covering the lens can be temporarily unfastened, so one can take a photo - and quickly fastened again. Currently I can only see some new 'cases' available on etsy - but they're not really cases - they just cover the bottom part, which is a bit pointless cos the rest of the body and the lens are not protected.
I think this camera has the same body shape as the Program A so whatever works for that applies too. Even if it's an every-ready case that's slightly too big would be helpful. Just not sure where to start.
Thanks
Ross
everready case example attached
