Hello!
I just bought a second hand Pentax MX and the previous owner told me that the light meter was fine and working properly lol it doesn't work. (Well, not quite)
The exposure issue I'm having is that when I replaced the LR44 batteries to see if it worked, the LED did work, but in a fixed position with underexposure and only for a few seconds. After that I can't turn it back on, only if I let the camera rest for a while and try to turn it on again.
I was looking for a solution here, but only found problems related to the lower circuit being bent and not making good contact.
I checked it like 5 times with a tester and it works fine.
So imagine that the problem came from higher up, specifically from the upper circuit.
Then I opened the upper frame but I couldn't see anything that was burned or any circuit cut, since it was open I did a little cleaning.
Could someone tell me if they see something strange or have any idea what can happen and how I could solve it?
I attach some images of the circuit and a video so that the state of this can be seen well.
Images:
Top circuit Pentax MX - Album on Imgur
Video:
Top circuit Pentax MX - Video on Vimeo
Thanks in advance!
