I just bought a late model LX with similar problems, hoping it was a sticky mirror problem, W/O batteries it seems to default to x synch speed only. With batteries, it seems to default to automatic shutter only, and it seems to return correct shutter speeds but it will not engage to manual speeds. I took a chance and it seems I bought a dud. Any suggestions?
---------- Post added 11-30-22 at 04:37 PM ----------
Post update; I tried an experiment with one of my Sunpak 544 strobes, open back, no lens attached I fired at a white floor, at speeds 1/2000, 1/1000, 1/500, 1/250, 1/125, x and 1/60, I could see how the slot distance between the curtains was increasing up to X that showed full frame illumination, in the at 1/60 and below, the second curtain took 13 seconds to release. When pointed at a 60-watt light bulb it took 2 seconds. In other words, from x to 1/2000 manual speeds work fine, below that it defaults to auto. Then at 1/2 second speeds go crazy again and seem to default to 125 seconds, approximately.
