Originally posted by TwoUptons I've had a number of cameras and lenses break on me...
Of the several MEs that I've had break (or arrive broken), I think all of them had mechanical failures, not electronic ones.
My H1a locked up once, and whatever happened took out the curtain streamers, so there was always a black bar on every photo after that... (recently fixed)
I had a PC35 literally come apart in my hands, and nearly all of them seem to have a bad flash catch...
I've had film transport and meter issues with MXs.
But I think every camera I've had made after the mid-80s that failed, except the MZ/ZX series, had an electronic failure, though several of those were from impacts or liquid.
Most of those were compacts... and man, I hate the "Err" indicators on the 90s compacts... "I'm broken and I won't tell you why... since even the error codes are obtuse..."
The MZs have all apparently been the mirror gear...
-Eric
I have to agree with you re the ME and ME Super, and if fact ALL the M series cameras, except the MX. They suffered a rmechanical problem which afflicts the wind-on hook-up, leaving the shutter uncocked. I've never found a satisfactory way of fixing it, although I did read somewhere recently of claims that a repairer had managed to sort out a fix, and done it to dozens of them. Sadly I can't verify that claim, and I know when I investigated it back in the early 1980s, I could see no way of resolving the issue, which seemed to be caused by simple wear to a fundemental part of one of the the wind-on levers in the base of the camera.
There will always be an issue with at least a small percentage of mechanical cameras having a fault at some time in their lifetime. It's a bit like a car that is never serviced or maintained-there will inevitably be a failure, and the vast majority of cameras will never be serviced until the day they finally cry enough, and fail . Fortunately, which brings me back to my original point, mechanical cameras rarely fail without some warning of an impending issue, so if a camera is working fine before it is taken out for a photographic session, the chances are it will still be working when needed. For example you cannot predict if the glue on the blind tapes is going to give up the ghost after your pre-check, however the chances of both letting go simultaneously is remote , and one will show an issue before they other goes. But almost, and I repeat almost, any mechanical camera can be resurrected if there is a failure, usually these days by using donor parts from a camera that is beyond redemption, and even that is sometimes for an economic reason rather than because it is truly dead.
I don't claim the K1000 is truly bullet-proof, but given the mechanism is very closely based on the preceding Spotmatics, it is going to be a very good bet it will outlast the user. In the 50 + years I have used Spotmatics, as well as collecting them, I have only one 'failure'. That was because a small pellet of metal from the manufacturing process ended up inside the camera body, until it eventually worked its way into a position where it jammed the wind-on. Removing the top, and shaking out the offending pellet solved the problem instantly! Yes, the meters can stop working, but usually because someone has left a battery in that has leaked, corroding the connecting wire(s). I've never encountered a failure of the meter galvo or the meter cells. And if we're being really accurate, yes, the stop-down switch does eventually stop returning automatically, and can only be fixed by stripping the mirror cage out since it it can only be reached from behind the front plate. I don't usually bother and return the switch to its default position manually. The K1000 doesn't have that problem, being K-mount.
