Hello,
After 51 years of producing 35mm film cameras and 46 years after the very first pentaprism SLR, Pentax launched what was to be their last film SLR body in 2003: The
*ist
This camera was launched alongside the company's first DSLR, named the
*ist D in what was one of the most dramatic milestones in photography's history: The change from film to digital.
Considered the lightest/smallest autofocus 35mm film SLR, it is really lightweight and compact. It was oriented for the entry level market. You can read more about it here:
Pentax *ist - Pentax Autofocus Film SLRs - Pentax Camera Reviews and Specifications
For a while I've been interested in finding one of these simply because it is the very last film SLR Pentax made to date. However, they are not very common. I was finally able to get a great deal on one from our own marketplace.
It is in good shape with only minor signs of wear and a few little cosmetic scratches. However, the previous owner reported the e-dial was finicky in operation. This seems to be a common issue with these cameras.
Sure enough, while still working, the e-dial has an attitude. I've been reading about this and it seems that accessing the e-dial internals is a nightmare. Haven't found a successful repair story online. I tried a little blast of electrical contact cleaner to no avail. But it still works so I'll leave it alone for now. The camera was cleaned inside and out but without disassembling anything. (hard for me
Been very light and small, why not test it with the smallest lens? The XS-40 which is not much bigger than a body cap!
Despite its digital crop sensor designation it's been reported to cover the full frame of 35mm.
So the lens was installed and fresh batteries went in. Out into the wild it went accompanied by a 1956 Brownie Hawkeye
You can read more about that comparison here:
Very odd couple on a date - PentaxForums.com
I loaded the very last roll of Kodak Gold 100 in my stash, expired about a decade ago. Fearing it may have lost some sensitivity, in many cases I dialed a +1 or a +0.5 exposure comp. You'll see it was not needed as the roll was perfectly fine.
I just received the online scans from the lab and the negatives are in transit.
These are untouched except for the signature and resize.
MFD and wide open:
Testing center weight metering on this one.
This is not a lake. This is some flooded land due to recent heavy rains.
and my favorite set of this roll: Guajataca river mouth.
Finally, my faithful companion of almost 17 years and 238,000 miles... I ordered it to the factory on January 2006.
Observations:
-Very capable!
-Surprisingly lightweight and easy to use.
-Similar in operation to a DSLR
-Need to check the options on the AF focusing points as I was using center point but when recomposing it changed focus despite been in AF-S. Need to read more on the manual.
-XS40 lens works perfectly fine on film
-As long as the e-dial holds, I see this as a very capable, easy and fun to use camera.
What do you think?
Thanks,
Ismael
