Originally posted by k0og Consdier a 35mm folder. I have a couple of Kodak Retina 1a cameras which work fine (zone focusing - you get used to it) for low-profile pocketable film-camera situations. If you really need rangefinder focusing, a Retina IIa works fine. Mine have the 50mm f2.8 lenses. Some IIa models have a 50mm f2.0 lens. Of course, pushing Tri-X or other fast film to 800 or 1600 might be necessary, and a steady hand is needed.
-Joe-
More or less exactly what I was going to write … I used a folding Retina with the 50mm f/2 lens on several occasions "back in the day" … if anyone noticed they certainly didn't comment or complain.
My film of choice for that sort of environment was usually Ilford XP1 (or later XP2
XP2 SUPER 35mm )
No neckstrap, case or other paraphernalia, kept it folded in an inside pocket, slipped it out for a couple of snaps as needed and put it away again
The rangefinder was perfectly adequate (and necessary with an f/2 lens wide open), the film coped well with the wide contrast between the spot-lit highs and the shadows at the back of the stage.
Do remember, in a wide-contrast environment like this, your lens (on what is likely to be an "older" camera) needs to be spotlessly clean to minimise flare.
