01-22-2023, 03:56 PM   #1
Advance lever problem with Super Program
I recently picked up an "as-is" Pentax Super Program which has a problem with the advance lever that I've never seen before. Basically, the advance does not ratchet, spring back, or actually advance anything; it just sort of freewheels, except for the standoff stop. At first, I thought it might be an issue with the rewind button, but I was able to manually advance the camera from the motor drive connection and everything seemed to work fine otherwise (rewind button popped out, film spool wound, and shutter cocked). As best I can tell, the displays are working and a reasonable exposure is being measured; by ear, the shutter also seemed to be correct.
I'm assuming that the issue is someplace in the top end of the advance and not any of the usual places inside the bottom cover. Before I go tearing into the top, however, I wanted to see if anyone else had seen something like this before and knew what might be wrong. Conversely, would it make more sense to leave it alone and just pick up a cheap Winder ME II?
Thanks...
01-22-2023, 05:11 PM - 1 Like   #2
Aaron28's Avatar
a spring may be broken on the lever mechanism.......since it winds from underneath why not a winder.....besides winders sound cool n look cool
01-22-2023, 06:28 PM - 1 Like   #3
Not a Number's Avatar
Probably the rewind/advance clutch in the take up shaft is stuck or broken. Getting at this is more than just removing the top plate.
Service manual is available here:
Product Details | Pentax Super Program Service Manual | Pentax | Service Manuals | Learn Camera Repair
Hope you have the proper tools, e.g. JIS drivers, spannersand the like.
advance, advance lever, button, camera, film, issue, lever, program, rewind, shutter, slr
Pentax auto 110 super slr - film advance lever is stuck need advice teamrums Visitors' Center 6 12 Hours Ago 11:41 AM
Auto 110 super - advance lever fires shutter toms21 Film SLRs and Compact Film Cameras 2 11-01-2021 08:20 AM
Pentax ME Super Advance Lever Misfire freefall Troubleshooting and Beginner Help 9 03-10-2015 03:48 PM
Super Program problem with film advance and shutter release Laurie60014 Film SLRs and Compact Film Cameras 6 07-18-2008 09:00 PM
ME Super film advance lever problem! Thursday Film SLRs and Compact Film Cameras 8 09-12-2007 12:07 AM
All times are GMT -7. The time now is 12:27 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
