Originally posted by tuco I shoot with the folding hood most of the time and my TTL prism laid idle for over a decade. One day I wanted to use it. I put it on and it didn't work. I did the usual of cleaning the contacts and verified the aperture chain wasn't broken (can happen if prism and lens are not installed in the correct order) and still nothing. But when I cycled the ISO adjustment back and forth from mininimum to maximum several times, it started working again. Maybe try that and see if you get lucky too.
Best of luck.
This kind of makes sense with my understanding of how these metering systems work. I don't have any experience with the 67 meter but it sounds similar to the basic "center the needle" type meter in the K1000.
The way these systems work is by balancing current between two separate circuits. Both circuits run current through the galvanometer. When the current is balanced, the needle is centered. If there is an imbalance, the needle is offset. One of the circuits is the CdS cell (aka the light meter). As the amount of light hitting the sensor changes, the current through the galvanometer changes. The second circuit contains a couple variable resistors which represent different aperture and shutter speed settings. As you change the aperture and shutter speed, the current through the galvanometer changes. The ISO setting is often couple with the shutter speed setting and they both share the same resistor.
When the exposure needle is pegged either high or low, it means that one of these circuits is open. With an infinite resistance, the current in the galvanometer cannot be balanced and the needle is held to one side. In the K1000, if the needle pegs low, that means the circuit containing the shutter and aperture resistors is open, usually due to some oxidation or corrosion on the contacts. If it's just some light oxidation, actuating the knobs and dials can be enough to "clean" the contacts and get it working again. That sounds like what happened in tuco's case. If that doesn't work, a good servicing should be able to get it back in working order.
