Originally posted by smata67 These have sat around for a bit and both are experiencing the same problem. The door doesn't engage when I close it. I have to "push" the edge of the film door inward, as if the door has stretched out a bit. See my attached picture, hard to explain in words. Door might also be a bit loose when closed. Will replacing the light seal solve these problems? Are there any adjustments that can be done to the door to improve closing? I've ordered a seal kit from Jon Goodman and will do the repairs, maybe that will help.
Replacing the seals is certainly a good idea with these old cameras. Otherwise, apart from very slightly bending the backs, there ar no adjustments available. But bending the backs shouldn't really be necessary, as these do (at least in my experience) not tend to lose their shape. After all, the construction is fairly (with respect to usual useage) stiff.
Ben
