Originally posted by Aaron28 yes it should the big deal would be an aperture ring
Originally posted by UncleVanya Autofocus lenses tend to have poorly dampened focusing action. So achieving reliable and repeatable results may be hard.
^^^ Both these points ^^^
Newer designs often/usually don't have aperture rings … they also are often only fully compatible with APS-C cameras, so you can end up with various degrees of vignetting, depending on the focal length chosen (on a zoom) or the aperture in use.
The focus action, apart from being "loose", is often relatively short throw, so setting it accurately, especially on a longer lens or with a wide aperture, can be a test of patience best tried on a tripod
Personally, I'd steer clear of a/f lenses on an m/f camera unless it was something special and/or cheap
