The AF280 has basically three modes of operation :
1) Manual : you control its output, although it offers only two levels, "H" (full) and "L" (low)
2) Auto (in the old sense)
: its own photosensor controls its own output, the AF280T has two sub-modes (red and green) which recommend different lens apertures which you must set on the camera yourself. These are not different "powers" by the way.
3) TTL : The camera controls the AF280T's output by shutting off the light when the film has had enough.
The first two modes work independently of the camera. But for the TTL mode the camera needs to be designed for it and the different camera brands all have different communication standards. Older cameras like the MX do not do TTL anyway, it does not have the contact for it, but
any camera with a hot shoe or a sync socket can use the manual and Auto modes.
The AF280T also produces an electrical signal for an indicating light in the viewfinder of some cameras, when it is charged up and ready to fire. This duplicates the "Ready" light on the back of the AF280T. The same "Ready" signal will also set the shutter of some cameras to sync speed automatically. The MX does none of this and does not have the contact for it, in fact it has only the single central trigger contact in its hot shoe. This article explains hotshoe contacts:
Hotshoe Configurations Originally posted by nicozanzibar if I need to use it with a flash gun?
The AF280T
is a flashgun. It can be confusing because not everyone uses the same terminology. Some people (particularly in North America) call them "strobes", others "Speedlites" or "Speedlights" which are actually brand names of Canon and Nikon (those two are always giving their kit similar names).
You can simply fit the AF280T into the hot shoe of your MX and use it in any mode except TTL. As
rpjallan said, you need to set the shutter speed to 1/60 (its sync speed) or slower (like 1/30); that is why it is marked in red as "60x" on the shutter dial. The flash will still fire if you set the camera to a faster shutter speed (like 1/125) but the photo will not be properly lit. If the flash does not work there is something wrong with either the camera or the AF280T. Does it flash if you press the "Test" button?
You can also use the flash separated from the camera, yards away if you want, by using a long sync lead plugged into the sync socket on the camera. However, the AF280T is not designed for this so you will need a small adaptor (inexpensive) to fit onto its foot that offers a sync lead socket.
The MX is a very good camera, and the AF280T is a reasonable flashgun although not over-powerful and rather lacking in modes. Beware of its weak battery door catch. I have owned several of them.
