04-01-2024, 06:32 AM   #1
Lens Cleaning
What ho one and all,
I want to buy some lens cleaning fluid but am confused as to what to buy. I had Eclipse E2 for cleaning the sensor but the plastic bottle has shattered and I have lost it all! I assume that if it is OK of a sensor, it is OK for cleaning lenses.
A Google search brings up all kinds of products, listed as suitable for spectacles and camera lenses, all at a reasonable price.
But if I search for camera lens cleaning, I get numerous Eclipse Optical Cleaning Fluid for Lens and Sensor at a rather more expensive price.
I do have isopropyl alcohol but not sure if this is suitable for lens cleaning.
What is the benefit of expensive Eclipse products over another product that also suggests it is OK for lenses and sensors?
Is Eclipse better than anything else or am I just giving the company directors a boost to their bonus?
Thanks and toodle pip
04-01-2024, 06:37 AM   #2
UncleVanya's Avatar
See this thread: Perfectly clean optics - PentaxForums.com
04-01-2024, 06:55 AM   #3
For general cleaning (not oil), I use a method learned long ago. Distilled Water and Q-tips. Dip the Q-tip in water and apply to the lens in repeating circles from the center to the outside, doesn't take much pressure. Then use dry Q-tips in the same circular motion until the glass is dry. Don't reuse a Q-tip. Helps to have a light that you can view the lens while doing it. Repeat as often as necessary until the glass shows clean under the light. Been doing this for years with excellent results.
04-01-2024, 06:55 AM   #4
Useful; thanks.
04-01-2024, 08:20 AM   #5
Not a Number's Avatar
Eyeglass lens makers (like Crizal) warn against the regular use of alcohol based cleaners on anti-glare coated lenses. The alcohol based cleaner I have actually warns the check before using on anti-glare coating. Warm water and dish soap is what they normally recommend.
Since eyeglasses are for every day use I wouldn't imagine the coatings are any more fragile than camera optics coatings.
Then there is ROR (Residual Oil Remover) which claims it is safe for all multi-coated optical surfaces. Just follow the directions - spray on lens tissue (not directly on optics) and wipe.
04-01-2024, 08:49 AM   #6
I've used ROR on the sensor to remove an oil/grease spot but never on a lens. Works great on the sensor for those stubborn spots.
04-01-2024, 11:05 AM   #7
Perhaps this:
Shop - Lens Clens
04-01-2024, 12:14 PM   #8
Organic solvents are the norm. From what I've read ether is/was a standard solvent to use, not so easy to get hold of now, I think you can still find ether based wipes. Note that many/most off the shelf optical wipes are alcohol+ water or even water based. I'll use cheap wipes like that to get the dust + smears off, then dampen a dried out wipe with a drop of acetone to final clean. I remember seeing a webpage or video on wiping technique: a continuous smooth circular motion that slides off the edge without leaving a smear. Definitely use medical/similar gloves to avoid any contamination/smears off your skin.
Some people say acetone is too strong but I've never had an issue.
I use naptha/equivalent (coleman fuel) for things like helicoids, or surfaces that have got something greasy on.
04-01-2024, 12:27 PM - 1 Like   #9
tonyzoc's Avatar
I use lens cleaning wipes and microfiber cloth. I've scratched plastic eyepiece lenses with q-tips so I don't use them on optics.
04-01-2024, 04:20 PM   #10
QuoteOriginally posted by Smoke665 Quote
The Qtips and water works but they don't remove the oil.
04-02-2024, 02:37 AM   #11
First, I use a blower to remove all visible dust. That can potentially reduce scratches.
Then, I use ROR Residual Oil Remover from B&H. I think it works great.
A PEC pad is handy for cleaning if at home. Otherwise, I use a clean microfiber cloth for optics, which I usually make sure to pack with me.
04-02-2024, 07:26 AM   #12
gofour3's Avatar
I've been using these Kodak lens cleaning papers for over 50 years, with their liquid solution.
Phil,
04-02-2024, 09:01 AM   #13
I'm really hesitant about applying any petroleum based cleaner to coated optics. From another site this is the composition of ROR
-85.118% Distilled Water
- 9.011% liquid soap
- 4.266% Isopropyl Alcohol
- 0.832% sodium chloride
- 0.755% Ammonia 26 degrees
camera, film, fluid, lens, lenses, price, products, search, sensor, slr
Help with cleaning/disassembly of SMC A 100mm f2.8 lens jjjfff Troubleshooting and Beginner Help 15 04-03-2024 01:50 AM
Lens Cleaning Fluid Question Lord Lucan Pentax SLR Lens Discussion 12 12-13-2018 01:53 PM
Please help; Adapting Pentax lens to Canon 70D, lens cleaning. StillSanj Welcomes and Introductions 4 04-14-2015 11:10 PM
DIY lens cleaning solution ??? Schick Troubleshooting and Beginner Help 27 10-13-2014 06:18 PM
All times are GMT -7. The time now is 05:43 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
