Originally posted by Douglas_of_Sweden Any chanse that the light meter could work?
I've bought several as incidental to other purchases. They tend not to work. You can tell this by looking at the auctions. Usually they are 10.00 - 15.00 and no guarantees or "no battery" or ... Frankly of the three I've gotten one worked kind of intermittently. I was after lenses and parts bodies when I purchased these... in each case the meter had caused damage to the body.
I don't like them a lot. Typically the buffer between them and the prism broke down. Then, in addition to all kind of other opportunities to dent the prism housing when fitting the meter, they would scratch the peak of the prism quite badly. With really bad luck, the battery leaked all over the housing and the finish is ruined.
Really, you want to ask two things: How does the finish on the prism look under the meter... an dents? And... does the meter respond to light? Chances are they don't have a battery, so it's a crap shoot.
I personally stopped buying these cameras with one of these meters fitted unless for parts. If I want one, I'll get a refurbished one and be done with it. But I don't. I use hand held meters. I prefer the small, clean look of these cameras without the meter. Some things are better left to history.
Originally posted by Douglas_of_Sweden Did they made the S1a and Sv in black?
Yes for H3v/SV, and Yes for H1a/S1a.
There's a broken SV on eBay right now in black...
Hope this helps.
Seaain
