Originally posted by SuperAkuma Excuse me for asking this dumb question but I don't see a point to using an easel in a dark room for a full size print. This is my first semester in the darkroom and I've printed a few print so far following the teacher's instruction.
I understand the easel is to help you frame the image on the enlarger and to hold down the paper flat. But if you are printing a full sheet an 8x10, whats the point? The paper that I've used are flat already. Can't I just put a marking on the base board where the 8x10 sheet paper will be and use that to frame the image when I turn on the enlarger? Also this way you get to print the image all the way to the edge without boarders.
I know you can buy some paper in rolls and you cut them to the size that you want. If you don't buy the paper in rolls and only print 8x10, are there any advantage to using an easel?
It's there to hold the paper flat. Just like a camera, the enlarger has a plane of focus and if the paper bows out of the plane of focus the image will be out of focus and soft.
You need some corner space for a place to stick the photo corners into, for the window mat to cover, etc anyway, so printing right to the corner is not a great idea anyway. If you don't like it, you can always just use a paper cutter to take a quarter inch off the edges once the print is finished.
