Originally posted by nekulturniy I have a question about that chart; it has a yellow exclamation point next the MZ-S, which says this:
Quote: Not Recommended. The image formed by the lens does not cover the full 24x36 frame resulting in vigneting (dark corners). Exceptions: Some users report that the DA 40mm does cover the full frame and that some DA zooms at least at some focal lengths also cover the full frame.
However, I'm not concerned about the image circle, just aperture control. It doesn't say anything about being able to control the aperture using a DA lens, which is all I really care about (so I can use future full frame lenses like the D-FA 100mm macro for example). Also, will SDM-only lenses autofocus on it? If they do then great, if not then it's not the end of the world.
Also, I don't see the MZ-3 on that chart at all (the other AF SLR I'm interested in). Is it compatible with DA lenses?
EDIT: I just noticed this message (not sure how I didn't see it the first time):
Originally posted by frank Actually you can use P mode on your MZ-10 to use DA lenses. The camera will set aperture for you, that's what I use when I'm using DA lens on a MZ-S and MZ-3, and SuperA too
Not sure if I'm cool with that though. I shoot in A-priority mode 90% of the time, and in M mode the other 10%. I'm going to have to test out shutter priority for a bit to see if I'm ok with that. The MZ-S, MZ-3, and MZ-5n are pretty much the only AF SLR's I like. Why did Pentax make so few high end 35MM SLR's? Most all have pentamirror VF's and look like cheap plastic.
