Originally posted by Stratman They WILL shoot wide open on a manual body. You can not stop them down since they have no aperture ring.
Sorry, but not the case. On M and K series bodies, a DA lens will be wide open to compose and stops down to its minimum aperture at taking time. The reason is that those older bodies are not forward compatible to the DA lenses. They give the aperture lever its full travel while A mount and newer bodies move the lever only as far as is needed for the aperture set by the body.
Ditto for A and FA lenses when the aperture ring is on the "A" setting.
(Have several pre-A film bodies...)
