Originally posted by Fixcinater Thanks for the links, I'll check those out.
Stop-down mode on my DSLR when using flash is a PITA (to the point that I never use strobes when M42 lenses are mounted), so I'm trying to avoid the same thing when using film.
Which model DSLR, I find the TTL flash on my *istD quite simple to use with M42 lenses, focus stop down and push the button, no thinking no PITA, it just works. It's one reason why I always recommend the *istD as a second body, it has functionality that sets it apart from all the other used bodies out there.
I admit I don't do this with my K10D or K7D because I woud consider using auto flash a PITA regardless of needing to stop down or not,
In this respect I also agree with wheatfield, a PZ-1 or PZ-1p would still be the best option because of TTL flash plus it is a good film back up body for all the lenses you use on your DSLR. It can even work with FA-J lenses, and DA lenses with KAF2 (crippled mount)
