Originally posted by tuco You can use the zone system of metering without applying the "zone system" to your shooting. And you can meter any manual camera of any format that way with a spotmeter.
So when I aim the spotmeter at a white wall for instance , I just say that white is 7 or 8 and turn the dial down 2 or 3 EVs to get the middle gray called 5 and, walla, there are your shutter/f-stop options for the shot to expose that wall to some degree of white is all. It is just a way of using a spotmeter that reads in EVs instead of shutter/f-stops like my old Pentax Spotmeter V does. It seems to work okay because my highlights come out the way I expect them when I develop my film.
I certainly see the uses for a spotmeter. On the other hand, for night work, you have to pick your zone, do the calculation, and then add something to compensate for the reciprocity failure. That is a good deal of calculating and reasoning. However, it seems from the terrific photos that have been posted that, at least for color film, the effect of averaging out the black to gray seems to negate the reciprocity problems, and the LX automatic metering gives great results. It is a neat fix (perhaps coincidental) that avoids all that effort.
Now, since Acros is reputed not to exhibit reciprocity failure, I wonder if shooting that film on the LX for night shots would result in over-exposure. There, you might need to use your spot meter and manually expose, rather than use the LX auto feature. Perhaps when my LX arrives back, I will try that experiment.
