04-02-2010, 06:25 PM   #1
Optech strap for MX, Super A?
I don't like the metal strap rings that came with my MX amd Super A because they can scratch up the covering on the body. Has anyone tried the Optech Pro Loop straps? If I remove the original metal rings, will the loop straps fit through the holes in the strap studs on the cameras? If not, any other suggestions?
04-02-2010, 06:49 PM   #2
Ratmagiclady's Avatar
QuoteOriginally posted by ziggy7 Quote
I believe they're supposed to be able to do just that. I use some Optech straps, though I've avoided the loops in favor of rings. I just use leather washers.
I think Mel here has used the loop links, I don't know if she cares for them much, but they should be plenty for a little camera like the ones you're talking about.
I do like the Pro Straps, (pretty sure that's what they call them. I call them 'boomerangs'. ) Like them pretty well, but the straps themselves may be a bit much for those cameras, unless maybe you use big lenses and/or winders: they do have smaller kinds.
04-02-2010, 08:56 PM   #3
I have Optech Pro Loop on all of my camera bodies. The answer is no. Without the metal rings (or whatever you call the triangular thingy), the Pro Loop won't fit.
I use a piece of leather (similar to the ones that come with the K7) around or under each of the metal rings to prevent scratching.
loop, metal, mx, optech, rings, strap, straps
Optech Pro Loop Strap in Taipei, Singapore, and HK? lsquare Pentax Camera and Field Accessories 2 07-08-2009 09:01 AM
Cleaning my OpTech camera strap heatherslightbox Pentax Camera and Field Accessories 3 08-15-2008 05:18 PM
Optech Super Classic vs. Pro Loop Straps Fireball Pentax Camera and Field Accessories 4 04-15-2008 05:08 AM
OpTech Pro Strap PeterAM Pentax Camera and Field Accessories 10 07-25-2007 05:53 PM
All times are GMT -7. The time now is 02:44 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
