Yep, I've used the AE-1P pretty extensively, actually. The A-1 is more the Super Program's opposite number in most respects: digital display, PASM modes, a compensation dial, etc. Same chassis as the AE-1P, though, (And both will take the Winder A, Winder A2, and Motor Drive MA, btw. ) The original AE-1 and similar ones can only take the Winder A.
I'd consider the AE-1P like a good courier bike, really nothing you don't need (Except maybe the Program mode, itself, why bother. It's so fast in manual, you don't need it,
) The meter's less sensitive on the very low end and not as precise, (Rather, a string of numbers that light up: this is actually pretty darn quick, you don't even have to consciously-read them, once you're used to them, and I have what I call a 'metering waggle' to get my precision, if I need that. I probably actually like em better than the A-1, all told, (At least being so used to them) and they all came with the brighter screen that was introduced midway through the A-1's run. )
Since there wasn't very sophisticated Program mode or meter patterns at the time, I really actually don't particularly recommend using it on cameras of that vintage. I used to be pretty dead-set against using program modes, until the automation started getting smarter. For me, I generally may as well set it myself, anyway. (Though I do like the hyperprogram mode on the modern cameras, kind of makes up for being harder to just set by feel as with old dials.
Yes, my old Canons are still in service, though.
Mind you, I'm quite fond of the Super Program, myself. I have the Super A for Pentax.
