07-30-2007, 05:00 PM   #1
Wrist strap for zx-l
Anyone know if there is a wrist strap available for the zx-l or how to rig one for it?
07-30-2007, 06:07 PM   #2
stewart_photo's Avatar
Many different wrist straps will fit this camera, Jonathan. Check around some of the more popular mail order stores, such as B&H...
wrist strap
Make sure you use a wider strap, not one intended for a smaller point & shoot camera with the tiny string through the camera lug.
Another alternative is to simply make your own strap. For my K10D, I found a strap from an older camera that was the perfect width for the camera lug. I then cut the strap long enough to wrap through the camera lug and around my wrist, overlapping by an inch about a half inch from the camera lug. I sewed the overlapping sections together repeatedly with heavy-duty thread. Afterwards, I covered the sewn area with about an inch of black electrical shrink-wrap tubing (for cosmetics only), carefully applying heat to shrink the tubing to fit the strap tightly. The end result looks like a a commercially made wrist strap.
The only disadvantage of my strap is that it isn't removable (other than cutting it off). This is not big deal for me since I only use a wrist strap. If you need a removable option, replace the sewn area with one of those little devices used to adjust the length of a strap. You may be able to salvage one off the old strap you used for this project.
stewart
wrist, zx-l
what do you think about this strap? 100dwes Pentax Camera and Field Accessories 3 09-02-2010 03:07 PM
Goodbye to neck strap; Hello Wye Strap!!! philbaum Pentax Camera and Field Accessories 42 08-12-2010 01:39 PM
Beautiful PENTAX wrist straps from Italian master TKH Pentax Camera and Field Accessories 27 12-30-2009 12:04 AM
R Strap Javelin Pentax Camera and Field Accessories 4 11-25-2009 01:17 PM
Strap to replace standard strap Mann Pentax Camera and Field Accessories 14 06-03-2009 09:35 PM
All times are GMT -7. The time now is 03:23 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
