Originally posted by Adam ME Super if you'd like to manually be able to adjust exposure.
If you're open to other bodies, I'd strongly recommend the
Super A or Super Program, which has everything- TTL flash, P, Tv, Av, and M all in a compact body for around $100.
Those are certainly nice although between a Super Program and the ME Super, for me it comes down to this: The ME Super has the nicer viewfinder, whereas the Super Program offers DoF-preview. It will also allow you to use lenses without an aperture ring. This might be interesting to those who own a DA lens that offers enough frame coverage. The DA 40mm ltd will, so will the DA* 200mm/300mm and the DA* 55mm.
And yet, it turns out that I've used my ME Super a lot more often than the Super Program. While I only occasionally miss a Dof-preview, I will always miss a superior viewfinder.
Having said that, maybe the OP should see if he can find a K2 instead, as unlikely as that is. It's the most elegant of film-bodies, Pentax or otherwise. As far as features go, it's only beaten by the rather unobtainable LX and it handles just as nicely.
There's one available on
ebay right now (the seller replaced the original photo he had ripped off camerapedia with one he ripped off from this side, but at least he added a note).
Cheers,
Tassilo
