05-17-2010, 04:54 AM   #1
Asahi Pentax Meter on S1a
Hi all, first post...
I acquired an S1a (and a Super A) from my grandparents, which came with the clip on Asahi Pentax Meter. The light meter battery was dead when I got it, and there was a bit of what looked like leaky battery gunge around that area. It's all cleaned up now, and I have soldered new battery connections in, where it had corroded. I put the new battery in, and now there is life
Problem is... how do I read it, and what do the letters B, H, and L stand for? I worked out the "off" bit by myself I am guessing it is to do with high and low light levels as to which one you use? If that's right then what is B?
Thanks for any help...
Tom
05-17-2010, 05:13 AM   #2
Moderator Emeritus
Post moved to Film discussion forum where it may get more responses.
05-17-2010, 05:29 AM   #3
Moderator Emeritus
the answer is contained here: http://www.pentaximaging.com/files/manual/Clip_On_Exposure_Meter.pdf
05-17-2010, 06:22 AM   #4
Thanks for that link. That is a slightly different meter - mine also has a green B setting on it, that isn't explained. What does that mean?
05-17-2010, 06:39 AM   #5
Moderator Emeritus
Can you post a photo of the meter?
05-17-2010, 06:49 AM   #6
Here it is
Tom
05-17-2010, 07:18 AM   #7
Moderator Emeritus
It may be a slightly different model but I think it works the same way. The "B" setting is for the battery. To test it. The H is for bright light metering (sunny days etc) and the L setting is for indoors and lower light settings.
You have to make sure you turn off the meter when not in use (it's not automatic) and the battery button was to test the meter and make sure the battery was still good.
05-17-2010, 07:20 AM   #8
OK, thank you, that clears it up. The battery is new, and the needle points to the green line when it's set to B which is good. Thanks again
Tom
05-17-2010, 09:17 AM   #9
Here's the manual. Available at the Pentax site. They have everything...
Hope this helps.
Seaain
03-23-2011, 02:59 PM   #10
hi what kind of battery does it take. in mine it looks pretty ancient
04-27-2011, 07:18 AM   #11
mcgphoto's Avatar
get a 675 used for hearing aids works like a bomb
asahi, battery, bit, light, meter, pentax, s1a
Asahi Pentax S1a 'bulb' shutter setting AndrewG NY Pentax Film SLR Discussion 12 07-10-2010 07:21 PM
Light Meter won't work on my Asahi Pentax KX AnthonyG Troubleshooting and Beginner Help 3 12-04-2009 03:14 PM
Asahi SPII My Light Meter Isn't Working. Cameron030293 Pentax Film SLR Discussion 7 10-13-2009 06:46 AM
questions on Asahi Pentax S1a or SV with lightmeter Douglas_of_Sweden Pentax Film SLR Discussion 8 01-19-2009 10:39 AM
Asahi Pentax ME, Light Meter not Working MacetheAce Photographic Technique 12 10-04-2008 02:31 PM
All times are GMT -7. The time now is 04:21 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
