Originally posted by lithos You're not just tucking the tip of the film into the needles, are you? What you need to do is push is under a few needles until it comes out again from under those needles. I like having a nice half-inch or so of the leader sticking out.
Ah. Ha. That might just be it.
Yes, I was just tucking the tip into the needles! I think I was just getting lucky because I would always watch and make sure the film was winding correctly so by the time I closed the back, there was at least a sheet of film over the part that I shoved it that, if it was winding tight enough, was probably keeping it in place. Hmmm...now I'm nervous about the film I have in there now!! Yikes.
I will give that a try once I'm through with this current roll. I never thought about having the leader stick back out from under a few of the needles. I always put it in from the left side as you noted but never back out from underneath again. It definitely fails to mention this technique in the manual.
I wonder if I'm the only one that didn't know??
Thanks!
