06-06-2010, 02:01 PM   #1
mz-s aperture reading problem?
Dear fellow Pentax users, I have recently purchased a used mz-s camera. When used in aperture priority mode or M mode, the aperture reading on the LCD is not the same as what is indicated by the aperture ring. For example, when I set the aperture ring to f/2, the LCD reads f/2.8, and when I set the aperture ring to f/2.8, the LCD reads f/3.5. It seems that the camera reads half a stop slower than the actual setting by the lens. Is this normal and is there any way to fix the problem? Thanks.
06-06-2010, 11:22 PM   #2
Do you by any chance have Exposure compensation set to something other than 0? Don't know if that would cause the issue stated but it's worth a look..
06-06-2010, 11:42 PM   #3
QuoteOriginally posted by JeffJS Quote
Thanks for the message...
No the exposure compensation is set at zero.
06-07-2010, 12:05 AM   #4
frank's Avatar
It's one of the issues w/ MZ-S cameras. Not so common, but I've seen it happened to a couple of my friends' copies. It's the aperture coupling problem. When it happens, the aperture shown in viewfinder is different from the one set on the lens aperture ring (in M or Av mode). It has nothing to do w/ the exposure compensation 'cause in M or Av mode, the exposure compensation only changes shutter speed, not the aperture. The problem will cause inaccurate exposure, overexpose in most cases.
The only cure is to send in for service. One of my friend sent the camera to Japan to repair this problem, cost him about $150usd. The other friend sent the camera to our local Pentax repair center, but they couldn't fix it ...
aperture, camera, f/2.8, lcd, mode, mz-s
K100D battery reading problem pamss Pentax DSLR Discussion 22 11-14-2016 02:47 AM
50mm f1.4 FA aperture reading not showing retrogaz Pentax SLR Lens Discussion 1 04-21-2010 01:43 AM
aperture problem with 50 1.7 kent Pentax SLR Lens Discussion 9 11-01-2009 05:11 AM
vivitar series 1 v3 f2.8-5_No aperture reading dcmsox2004 Pentax SLR Lens Discussion 5 04-05-2009 06:08 PM
FA 24-90 aperture problem penpig Pentax SLR Lens Discussion 1 01-26-2009 10:08 AM
All times are GMT -7. The time now is 12:00 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
