06-28-2010, 12:22 PM   #16
GeneV's Avatar
QuoteOriginally posted by magkelly Quote
Try your local grocery store, no kidding. The only places I've seen Kodak recently were at grocery stores. All the drug stores here have the Fuji brand, but all the grocery stores here seem to have Kodak. It's usually with the batteries and such. But yeah, I'd check the dates. I'm sure film moves very slowly at the grocery stores these days.
Walgreens has their own branded Fuji, but also has Kodak. It also does processing, but they recently doubled their price to $4.50 for a 36exp roll of negatives only. At least they are still doing the processing.
The availability of inexpensive local processing is one of the reasons why I shoot color and B&W negatives almost exclusively these days when I shoot film. Years ago, my 35mm color would have been about 75% slides.
To your original question, I don't think you will be put off by consumer film. I ran out of Fuji pro stuff on my recent trip and shot a roll of Gold 200. It was quite nice. It is a little more saturated, but with scanning and pp, it worked just fine.
06-28-2010, 01:10 PM   #17
ismaelg's Avatar
On the topic of the meter: Do you plan on taking a DSLR as well? You can use it as a metering reference and get a feeling for the older one. You'd need similar focal lenghts and I'd set the DSLR to centerweight metering. Just a suggestion. Your mileage may vary.
Thanks,
06-28-2010, 03:14 PM   #18
GeneV's Avatar
Thanks,
I do that all the time for flash metering using off-camera flash. I take a few digital shots, look at the histogram, then burn some film.
06-28-2010, 07:43 PM   #19
Ektar will probably be hard to find in a pinch, but it's a great all around film and would be nice if you can find it.
I've seen great photos taken with Gold, but I don't ever shoot it. Fuji Superia and Sensia too.
The C-41 B&W films are pretty nice too. You should be able to find the Kodak version at CVS etc. Matter of fact, I was at the CVS down the street the other day and they had Tri-X! Real honest to goodness B&W film. Can you believe it? They can't process it, but they sell it.
06-29-2010, 04:10 AM   #20
pcarfan's Avatar
I appreciate all the responses, very helpful. I am certainly taking my DSLR, which will be my primary tool. I am 'experimenting' with the SLR as I haven't used it in a while and only for snapshots before.
06-29-2010, 06:42 AM   #21
GeneV's Avatar
QuoteOriginally posted by pcarfan Quote
If you are "experimenting" with the SLR, then I would suggest that the consumer film, such as the ubiquitous Kodak Gold or Fuji Superia, are just what you need.
Ektar is a superb but challenging film, and I would not suggest learning on it away from home where your photos are important. I just shot my first roll of it, and I would want to go through a few more before taking it on vacation. However, once I do get to know it, it probably would be my choice for a landscape-heavy trip.
06-29-2010, 07:11 AM   #22
pcarfan's Avatar
GeneV that makes a lot of sense.
I bought some Ultramax 400 at the local CVS.
Thanks.
06-29-2010, 12:46 PM   #23
pcarfan's Avatar
QuoteOriginally posted by Vertex Ninja Quote
Checked the counter again at my local CVS and they had both as well, grabbed a Tri-X, but now I don't know whether I want to load the B&W or color, dang!
06-29-2010, 05:15 PM   #24
ChrisPlatt's Avatar
Kodak Gold 100 is an excellent film, if you can find it. Costs less than Ektar, too.
Chris
06-30-2010, 04:52 PM   #25
Kevin,
How reliable is the sunny 16 rule? can I use a shutter speed of 1/400 with iso400 film and aperture of 16, even if my camera reads it as +1-2EV? If the sunny 16 is relaible or you have used the 400 film well under bright light and kept the shutter below 1/1000, I could go with your suggestion.
Thank you!
I've used the Sunny 16 rule often but with BW film. It is very reliable but as Steve noted you need to gauge how sunny is sunny. Look for sharp shadows as a clue and note too extra bright scenes such as the beach require a Sunny 22 rule, if you will. And the Sunny 16 is a function of the year and your latitude. Fall/Winter/Early Spring may need the Sunny 11 rule especially at higher latitudes.
You can use 1/500 for ISO400 @ f16. Negative film has latitude. If it's nice and sunny, why not shoot 100 film for your landscape? And since you have a whopping 36 frames per roll (that's a lot from what I'm use to), you can bracket when in doubt
06-30-2010, 05:45 PM   #26
pcarfan's Avatar
Thanks!
Did you say 32 exposures ? well! I am taking a brand spanking new 500GB hardrive good for a couple of hundrad thousand pictures........... AF-C, Hi-speed firing, 5-exposure bracketing with one click - cocked and ready to fire
I am looking for the grainy sort of film look with the 35mm, so 400 would be better. I am moslty relying on my K-7, the super program is for the vintage look only. Mostly I would do Tri-X 400 only with the SLR.
In the mean time, I've treated myself to a fine vintage gift and should receive it in a couple of weeks, and pretty soon I'll have to learn to limit myself to 12 exposures a roll (like I think you are used to) . It's such a vintage it predates Pentax.
06-30-2010, 06:09 PM   #27
Thanks!
That hi-speed firing is a slow fps, many megapixel, short burst, no sound video and you frame grab your still.
07-01-2010, 03:02 AM   #28
pcarfan's Avatar
Ah! that's why I hear 5.2 fps to be too slow....... when compared to video, it is....now, I get it
07-01-2010, 05:55 AM   #29
pcarfan's Avatar
This 'discussion' about available exposures has given me an idea. I am going to use the 24 exposures of the Tri-X 400 I have and try to capture the essence of yellowstone and Grand tetons within the 24 frames. That I think would be a nice project. I am going to narrow it down to Yellowstone landscapes only, as fauna and flora is just too much. If they turn out as I am hoping to, I'll post the results later.
07-01-2010, 06:42 AM   #30
GeneV's Avatar
Ansel will be watching from above.
consumer, film, landscape, shots
What to look for in consumer laptop? Ratmagiclady Digital Processing, Software, and Printing 49 02-04-2010 06:49 PM
Consumer Ratings res3567 Pentax DSLR Discussion 0 09-28-2009 07:57 PM
Consumer zoom or manual * Recercare Pentax SLR Lens Discussion 16 09-10-2009 08:15 AM
Consumer Reports and Pentax storm Pentax DSLR Discussion 50 07-13-2007 01:45 PM
Consumer Protection JCSullivan General Talk 8 10-21-2006 07:08 PM
All times are GMT -7. The time now is 05:59 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
