07-30-2010, 06:14 AM   #1
unixrevolution's Avatar
Pentax *ist Selection Dial problem
My friend recently bought a *ist off the forum here (through me), and it has a problem with its selection dial (E-dial, if you use the term the DSLRs use.) Basically, you can select the mode, but once you're in a mode (say, Av) you can adjust the aperture one way but not the other. The dial only spins one way, and unfortunately doesn't loop around!
Pentax has no parts and won't work on it, does anyone know who I can send it to?
07-30-2010, 07:06 AM   #2
How can Pentax not have any parts for it? The e-dials were the same across all the *ist bodies...
07-30-2010, 07:12 AM   #3
skyredoubt's Avatar
Does it physically not turn or turns, but fails to change the aperture?
Anyhow, how about trying this - TV-Tuner/Control Cleaner & Lubricant:
TV-Tuner/Control Cleaner & Lubricant - RadioShack.com
-$11 at RadioShack - it saved my *istDs when the dial stopped working properly.
Basically, it removes dirt and such from the contacts.
07-30-2010, 11:07 AM   #4
Adam: This is the FILM *ist body, not a *ist D/DL/DS. The E-dials on the digitals are totally different.
https://www.pentaxforums.com/forums/pentax-autofocus-film-slr-camera-reviews/...ntax-*ist.html
The dial turns one way, but physically WILL NOT turn the other way. It feels like a mechanical defect, not a problem with dirt.
07-30-2010, 11:15 AM   #5
I'd take the camera to your local repair shop. Maybe they won't need to use new parts to fix it.
08-10-2010, 06:00 AM   #6
I don't have one of those.
*ist, mode, pentax, selection
E-DIAL wheel on PENTAX IST DS help please grgo12 Pentax DSLR Discussion 29 05-01-2015 02:13 PM
ist* DS select dial problems psycorpse Pentax DSLR Discussion 3 07-23-2009 05:43 AM
Preview dial on *ist DL? winglik Pentax DSLR Discussion 4 04-08-2009 05:43 PM
E DIAL on Pentax ist ds broken? help grgo12 Photographic Technique 0 10-31-2008 11:58 AM
Pentax ist*DS - Bad rotary dial awjweb Pentax DSLR Discussion 13 03-20-2007 08:42 AM
All times are GMT -7. The time now is 11:03 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
