Originally posted by sam.p Hello,
I'm having an issue with my light meter on my MX. Is there any way I can calibrate it . . .
You didn't say what sort of miss-calibration you were experiencing. If the exposure is consistently and linearly off (high or low) it may be dirty contacts in the ASA (ISO) setting mechanism. Just exercising the dial might solve the problem. Unfortunately, the electrical contacts aren't as accessible for cleaning in the MX as they are in the ME/K1000/SP bodies.
If the issue isn't linear throughout the exposure range, or varies with exposure settings, the issue may be with either the aperture (lens) or shutter mechanism (camera) -- or both.
You can define the problem fairly simply by making an exposure table and taking readings of the clear north sky. Readings should follow the standard reciprocal pattern of speed versus aperture. You might also do a comparison with a second light meter or TTL camera as a confidence factor.
Define your exposure error through trial first. You may find an internal calibration isn't the solution. As a user camera, sometimes just compensating a known EV error with the ASA dial is the easy/economical solution (even if it's not a linear error).
H2
