09-05-2010, 12:35 PM   #1
Pentax Mx
Salve a tutti, sono un nuovo utente
Purtroppo ho avuto un problema con la Pentax Mx di mio padre, si rotto il carrello manuale del rullino
Sapete se pu tornare indietro automaticamente? o se ce un modo per aggiustarlo?
Per favore aiutatemi, ci tengo molto!!
Grazie
09-05-2010, 03:23 PM   #2
What exactly do you mean by 'manual roll'?
09-05-2010, 05:31 PM   #3
Marc Sabatella's Avatar
Since as far as I know the Mx is a film camera, not a DSLR, I'm moving this to the proper forum.
09-06-2010, 12:28 AM   #4
goddo31's Avatar
Buongiorno hixop,
Unfortunately it is a little hard to understand what the problem is, due to the automatic translation.
Do you mean that the manual film advance is broken?
If you can find a really good Pentax repair technician, most problems with the MX can probably be fixed.
If you press the small black button on the under side of the camera, can you then move the film advance?
Welcome and I wish you luck with the MX, ciao
09-06-2010, 04:23 AM   #5
octavmandru's Avatar
Hello
"carrello manuale del rullino" I guess it means the manual rewind is broken.
Mx is a manual rewind camera only. So you will need a technician or a similar broken camera to replace the part.
Unless you mean the black button doesn't work, and then the repair shop is the only solution.
Octav
09-07-2010, 12:42 AM   #6
Si esatto, il carrello manuale del rullino, infatti ora la spedisco.. ci tengo troppo
grazie mille a tutti
09-07-2010, 05:10 AM   #7
titrisol's Avatar
Location: In the most populated state... state of denial
I think you need to look at the manual
in English here
I do not know if you can get it in italiano
mx, pentax
All times are GMT -7. The time now is 02:39 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
