With the amount of oil you are describing, it is likely the person who had this camera before you tried to repair it with oil. Slapping it on your hand had an interesting effect. This means there may be resistance in the release mechanism which operates the shutter and mirror. The thing is you have to tool up to repair it. If electrical, cost of repair will exceed value of replacing outright. On the other hand, if this camera has sentimental value, it's going to be resurrected at any cost or sit out the remainder of it's existence on your desk.
I'll buy the illumination window (undamaged) for $10. I can use it to replace the one in my camera. Also, if this is a black body, and the top cap is perfect, I'll give you another $15 for that. Benefits to you? $25 for parts off your camera which you won't be able to recover your money anyway, and you get to learn what makes it work! I'll even throw in another $10 for postage. The winder is worth $40 tops, and the back is another $10, in my opinion. That makes your camera body and winder worth $75 if parted out. That's a start on a used ZXn5 and a little better performance...unless you get one with a bad shutter curtain motor. Man, there is no end to this unless you have really good luck!
Reason: ,isspelled words, added text
