Closed Thread
09-29-2010, 11:10 AM   #1
Ole's Avatar
Pentax S2 (H2)
The S2/H2 was released in 1959, a year after the 'K'. The S2/H2's top shutter speed was reduced from the K's 1/1000s to just 1/500s, but there were a number of advancements. The S2/H2 was the first Pentax to use a single speed dial and the camera included a Fresnel focusing screen. Also, unlike the previous models the shutter speed dial did not rotate when the shutter fired. Another improvement was a small window on the top plate which would turn red when the shutter was cocked.
During this period, Pentax traditionally released it's cameras within the North American market through a distributor. This was the first Pentax camera that the Heiland division of the Honeywell Corporation brought into North America, and the name 'H2' was presumably chosen for them. The camera was released as the S2 in other markets except South Africa where the camera was called 'Asahiflex H2' due to the name 'Pentax' being a trademark of another company.
Asahi Pentax S2
Also marketed as
Asahi Pentax H2
Heiland Pentax H2
Asahiflex H2
Year introduced
1959
Year discontinued
1962
Mount
M42
Automatic aperture stop down
Yes
Metering
No light meter
Exposure modes
Manual, B
Shutter speeds (auto)
Not applicable
Shutter speeds (manual)
T, B, 1 - 1/500s, X
Shutter speeds (mechanical)
T, B, 1 - 1/500s, X
Self timer
Mirror lock-up
Auto bracketing
Not applicable
Multiple exposures
Yes
Winder
Ratchet type rapid wind lever
Flash hot shoe
Built-in flash
TTL/P-TTL flash
Flash sync speed
FP and X terminals - 1/50s
Flash exposure comp
Not applicable
Viewfinder type
Pentaprism finder with Fresnel lens + microprism
Diopter correction
Exchangeable screen
Depth of field preview
Through switch on lens where available
Image size
24 x 36 mm
Battery
None
Size (W x H x D)
143 x 92 x 47mm
Weight
548g
Comment
The 'S2' /'H2' model came in an early and a late model. The late type has coupling for a light meter on the shutter dial.
PENTAX K20D  Photo
PENTAX K20D  Photo
PENTAX K20D  Photo
PENTAX K20D  Photo
Closed Thread
camera, lens, model, name, pentax, pentax s2, s2, shutter, speeds, type
All times are GMT -7. The time now is 08:04 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
