10-03-2010, 10:46 AM   #1
Help with marks on film.
I recently shot a roll with my SV and a few of the frame have some strange marks on them. they are the same 3 marks in the same spot on 3 or 4 different frames. They turn out bright like a light leak would but don't look like any leaks I have seen. Could it be a leak in the shutter curtain? Or a scanning issue?
Any idea what the are?
10-03-2010, 11:29 AM   #2
You could eliminate scanning issues by rotating the neg 180 degrees and seeing if the marks stay on the same side. Looks like light leak to me though. Have you checked both shutter curtains?
10-03-2010, 11:53 AM   #3
It looks like it could even be damaged negatives from poor handling. What do the marks look like on the negatives themselves?
10-03-2010, 12:45 PM   #4
fotaki's Avatar
QuoteOriginally posted by PeteyJ Quote
Agreed. These look like typical 'kink' marks caused in handling/loading of film prior to processing. Did you process the film yourself - say in a spiral unit? If so, then this could account for the marks viz, difficulties in threading the film. Kinking causes localised pressure on the emulsion which results in a higher density in those areas during processing (darker crescents on the film).
If this film was Lab processed then I think you have every right to complain.
10-03-2010, 01:20 PM   #5
Thanks guys.
I checked the negatives and I couldn't see any thing out of the ordinary, but it definitely makes the most sense.
I didn't really have a cap on the lens for most of the roll, so that makes me wonder about the shutter curtains.
I will have to run another roll through and see what happens.
10-03-2010, 10:25 PM   #6
Otis Memorial Pentaxian
They look like kink marks to me too.
10-03-2010, 10:44 PM   #7
The second shot looks like kink marks but it seems odd that the marks are in the same position on each frame. I can't see how you could kink film with that consistency? You can usually see kink marks on the negs with the naked eye.
10-03-2010, 10:54 PM   #8
QuoteOriginally posted by Vendee Quote
A bad developing reel could easily leave a consistent kink mark on the film.
10-04-2010, 12:57 PM   #9
How could a bad reel leave a kink mark at the same position on each frame?
10-04-2010, 01:40 PM   #10
If it's stainless steel, it can't. But with a plastic reel, if there's a warp or other kind of imperfection where you feed the film in, it can leave a kink mark in every frame as you load the film. I just had to buy some new reels not too long ago because a bad reel was messing up my film.
10-04-2010, 02:15 PM   #11
I looked fairly closely at the negatives and the film is perfectly smooth with no kinks that I could see.
10-04-2010, 07:07 PM   #12
I think it's more likely a light leak than film kinks. It may be a leak around the mirror. Have you checked to see whether the mirror is closing completely when the shutter is open? (I'd expect the marks to be closer to the film edge if the back was leaking.)
John
10-04-2010, 07:16 PM   #13
Ratmagiclady's Avatar
QuoteOriginally posted by Swift1 Quote
The key part there is if the emulsion cracked, which doesn't require the film base to take a visible set. We used to call em 'fingernail marks' which would be a big time misnomer.
10-05-2010, 12:02 PM   #14
QuoteOriginally posted by John Poirier Quote
I think it's more likely a light leak than film kinks. ...
Both a light leak and a kink would show up dark(er) on the negative. Maybe the camera loaded the film slightly off, causing these problems until it straightened itself out. If there is nothing on the negative, then I'd look at the scanner. Did you scan these yourself? It could be dust on the the glass, mirrors, or sensor.
For what it's worth, it looks a lot like when I'm a little aggressive with my pressure on the sides of the film during development. Usually if it happens it's on the first or last frame.
leak, marks
Pentax K-x, marks on certain photos Swevener Pentax DSLR Discussion 4 09-14-2010 08:26 AM
Red Scratch marks? BlueEyes Troubleshooting and Beginner Help 3 11-29-2009 06:33 PM
Red marks on SMCP-M 1:2.8 28mm MrEspie Pentax SLR Lens Discussion 2 05-02-2009 09:03 PM
tasty lens marks a milestone timbo13 General Talk 15 04-14-2009 04:32 PM
What are these red marks in the leaves, K10D? WildSioux Photographic Technique 29 06-23-2007 12:35 PM
All times are GMT -7. The time now is 02:02 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
