11-01-2010, 06:38 PM   #1
Wombat's Avatar
Anyone calibrate a hand-held meter?
I have a Quantum Calculight XP which is consistently reading a full stop low. At ISO 400, for example, my other meter and various cameras will all give a reading of, say, 500th at f4 but the Quantum will read 500th at f2.8. This happens at all ISO settings. I've tried new batteries and yes I could make a mental compensation, but you know how it is in the heat of the moment - easy to forget or compensate in the wrong direction.
Does anyone know how to calibrate one of these?
Les
11-01-2010, 07:21 PM   #2
Digitalis's Avatar
Quantum have an online manuals section, however you have to register to access them. I would recommend that you should start there.
their page can be accessed here
are you using the meter as a flash or ambient meter?
11-02-2010, 10:00 AM   #3
I'd expect a handheld to give a different reading then the camera under many conditions. So you're saying if you hold the meter up to, say, a white wall and did the same with the camera and other meters they differ by one stop?
11-02-2010, 02:08 PM   #4
Nesster's Avatar
I've calibrated an old GE II meter - it is a simple screw driver job. Are you asking about where on your meter might a calibration control be?
11-06-2010, 06:09 AM   #5
Wombat's Avatar
Thanks for the responses, gents. Digitalis, I'm using the Quantum as an ambient meter. And I already have the manual but it doesn't tell me how to calibrate the beast.
Tuco, yes, I've done exactly that and the other meters, including another hand-held, all differ by one stop consistently.
Nesster, yes I'd like to know where the adjustment screw(s) is/are and how to actually do the calibration. I've taken the cover off and inside, sitting on the circuit board, are four small blue rectangular objects, each with a screw sticking out, which I imagine must be the adjusters. I'm nervous about twiddling with them in case I totally wreck the thing.
Any further advice would be much appreciated.
Les
calibrate, iso, quantum
Night Fireworks/ hand held terptracey Post Your Photos! 1 07-06-2010 12:08 PM
67 -vs- 645N hand held Matus Pentax Medium Format 2 06-03-2010 04:46 PM
Hand Held Lightmeter Brianog Pentax Film SLR Discussion 22 01-12-2009 10:42 AM
Flash - Hand Held Sailor Post Your Photos! 1 12-22-2008 09:23 PM
Hand Held Meter mysterick Photographic Technique 6 12-09-2008 04:15 AM
All times are GMT -7. The time now is 08:35 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
