Originally posted by sharpshoota Really. I didn't know i could use my DA lenses on my PZ-1P? I would love to use my DA 12-24mm. How do I do it exactly?
The wheels on the Z-1P, makes it possible to stop down lenses that do not have aperture ring.
You can use the DA lenses that have the full image circle of 24x36, (and of course the DFA lenses). Richard made a run-through of the different lenses :
“I have checked all the DA's except the kit lens and they are as follows:
10-17 FE - Usable from 14mm up
DA 12-24 - Usable from 16mm up
DA 16-45 - Usable from 20mm up
DA 50-200 - Not usable, vignettes at varying (small) amounts, never quite clears
DA 14 - Unusable, large image circle visible
DA 21 - slight corner image circle
DA 40 - Usable, no vignetting
DA 70 - Usable, no vignetting“
Jim King wrote :
“I took a test series using the DA40 on my MZ-S and found no vignetting even wide open. I felt that at f2.8 the edges were not quite as crisp as the central part of the image, however. In any event, the DA40 does cover the full 24x36 frame.”
Somebody else, can’t remember who, wrote :
“The ZX-5n will work with lenses that lack aperture rings, with the following limitations:
In Av and M modes, the lens is always "wide open". There's no way to set the aperture to anything narrower than wide open.
In P and Tv modes, everything's fine. Tv becomes your only way of *indirectly* controlling aperture; want a tighter aperture, dial in a longer shutter speed.
Exposure compensation works as it should, but again, you have no direct control over aperture. In M and Av, it's wide open. In Tv and P, the camera selects for you.”
To Rickard : Had I not been a student, I’d love to help you out regarding the MZ-S; (particularly with the handgrip). But LBA takes precedent
. Otherwise, I like the idea of buying from people on the forum. Gives you an idea of how it has been taken care of.
