Hi Jeff, and all!
I swear I'm not trying to hijack your thread....
I don't have a stereo adapter. In fact, I hadn't even heard of stereo photography before last Thursday, when Volosong mentioned it in a post on another thread.
But since last week, that's all I've been thinking about...
Apparently, as others have noted above, the adapter you have probably won't work on DSLR because of the crop factor, but googling has lead me to another
link over at OK1000 that claims Pentax did make a version of this for DSLRs. There is a link from there to Pentax.jp site that shows it. Any ideas on how to get a hold of one?
It looks like that adapter Jeff has is 1/2 of a set. The other 1/2 is a viewer that allows you to view the images in 3D. Anyone know what viewing method is used by that adapter? Can you see the images in 3d using the cross-eyed method without the viewer adapter?
Since I don't have one of those, I used the base plate of my Manfrotto 303sph to slide my K100D side to side about 6-8 inches and got the following results from 2 shots. The adapter would be cooler, because you could capture action shots by getting both shots in a "single click"
To view this in 3d, make sure to read the instructions linked to by konraDarnok. I just realized that this isn't the "Post your photo" part of the forum, so I'm just posting a link here:
My first 3d image
I've been viewing a lot of pictures via the cross-eye'd method over the past few days, and it isn't so hard, once your eyes get used to it. I also found
this software which will convert your dual images into either 2 side-by-sides, or converge them into a single image for viewing with a number of different kinds of 3d glasses. I'm not sure if that software would work with shots taken by the adapter, but it does make it easier to matte the results using a dual image technique
Very cool stuff!!!
-Chris
