02-01-2011, 08:15 PM   #1
Cleaning Mirror , Viewfinder
Is there a correct way to clean the camera mirror? I have some dust ? when looking through viewfinder on a K1000......
02-01-2011, 08:29 PM   #2
Ratmagiclady's Avatar
QuoteOriginally posted by MIKESDEALS Quote
Well, quick answer is, don't touch the mirror, for starters: the silvering is on the face of it and it's quite delicate. Besides, if you can see it when looking through the finder, it's much more likely to be on the focusing screen. A rocket blower can probably get that out of your way with a little fussing.
02-01-2011, 08:42 PM   #3
Otis Memorial Pentaxian
What she said, but adding to not touch the focus screen either. The screen is also very delicate and easy to damage. A manual blower is the best tool for the job. Don't use canned air. If you can't get it clean with the blower, take it to the shop. They can do a wet cleaning using materials that will not harm the mirror or the focus screen.
02-03-2011, 01:15 PM   #4
I attach a large soft drink straw to a vacuum cleaner. It works much better. I also examine the surface with a magnifier to locate the dust particle.
02-03-2011, 03:53 PM   #5
ChrisPlatt's Avatar
When I worked in camera repair at Olympus in the mid-1980's we cleaned SLR mirrors with wadded up lens tissue and Freon TF.
Dire warnings that the mirror can never, ever be touched are slightly overstated. Regular cleaning is not recommended, but the
occasional fingerprint can be gently cleaned with a soft lens tissue and a little breath fog, or a drop of lens cleaner if badly soiled.
That said the coating on the mirror is very soft and easily scratched, so a good deal of care must be exercised when cleaning it.
The focus screen on most modern SLRs is plastic. Dust can be removed with a blower or carefully with a soft brush if necessary.
Liquid cleaners will only make it worse and may ruin the screen. A badly soiled screen should be professionally cleaned.
Chris
mirror, viewfinder
Viewfinder Mirror issue AbsoluteZedo Troubleshooting and Beginner Help 27 10-20-2010 07:45 AM
Mirror lens cleaning Eruditass Pentax SLR Lens Discussion 5 08-20-2010 08:42 PM
Smudge mark on mirror cleaning? iht Pentax DSLR Discussion 3 07-13-2010 03:25 PM
Pepsi on viewfinder eyepiece, cleaning help needed. Cosmic Debris Pentax DSLR Discussion 6 05-05-2010 02:38 PM
Dust in the Viewfinder - Cleaning Tips? International9300 Pentax DSLR Discussion 4 06-24-2008 07:45 PM
All times are GMT -7. The time now is 07:59 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
