02-16-2011, 01:39 PM   #1
One quick question about MZ-S
Does it take DA lens ?
Can I use AV mode ?
Thanks !
02-16-2011, 01:45 PM   #2
No, you can't enter AV mode as you need to be able to move the aperture ring to do that. Also, remember that DA lenses don't cover the FF format (except for the 40mm).
The PZ-1 supports AV mode on DA lenses as it has two scroll wheels.
02-16-2011, 01:45 PM   #3
Banned
QuoteOriginally posted by nannankevin Quote
Can I use AV mode ?
Thanks !
1. your DA lenses will work yes. not all of them will completely cover the full film frame, as they are not intended for use on 35mm film. the longer the focal length the more likely it will cover the full frame. the wider the more it will vignette.
2.yes
02-16-2011, 01:47 PM   #4
Banned
No, as you need to be able to use the aperture ring to do that (I think). Also, remember that DA lenses don't cover the FF format (except for the 40mm).
why would a DA lens not be able to use Av mode on an MZ-S? it will communicate just the same as any manual lens with the ‘A’ setting on the aperture ring will it not? im confused on this. im sure any DA lens will be able to take advantage of Av mode.
02-16-2011, 01:55 PM   #5
Right, but on the MZ-S, you have to use the aperture ring to enter Av Mode. The scroll wheel is only for shutter speed.
02-16-2011, 03:09 PM   #6
Banned
but isn’t a DA lens basically like a lens thats permanently on the ‘A’ setting? you have an MZ-S yes, so you can try? im still a bit confused, because the lens would have to be on the ‘A’ setting anyway to use any program AE mode would it not? or does the MZ-S do Av like the older manual cameras such as say an ME super?
02-16-2011, 03:21 PM   #7
Yes, it can sense the aperture based on the aperture ring position. It isn't "crippled".
02-16-2011, 03:24 PM   #8
Banned
shows how little I know of the contemporary Pentax film cameras.
02-16-2011, 04:16 PM   #9
On MZ-S and MZ-5N, you need to turn aperture ring to set Av mode. On MZ-6, you can use in-body control to set Av.
02-27-2011, 12:23 PM   #10
QuoteOriginally posted by violini Quote
Think of the MZ-6 as a cheap alternative to the MZ-S. It doesn't have the 2 second MLU, the viewfinder is dimmer, and the optional AA battery pack FG is not as useful as the MZ-S' (but at least one is available). These are the only functional disadvantages. The MZ-6/ZX-L has DOF preview as well, which I find to be a very useful feature.
The MZ-6 has 2 advantages over the MZ-S. Firstly, as mentioned, you can control the aperture through the body. Secondly, you can set the camera to spot meter by just hitting the AE-L button and it will then reset itself back to matrix metering. On the MZ-S you have to remember to turn a switch to take the camera off spot meter mode, and I've wasted many a shot on the MZ-S because I've forgotten this.
02-27-2011, 05:23 PM   #11
Don't forget about the data imprint feature, too! (or does the MZ-6 have it as well?)
02-27-2011, 06:43 PM   #12
Good point. Another +1 advantage for the MZ-S. I didn't think about it because I take hand written notes of all my pictures, so I don't use this feature.
Quick question Mark R Pentax SLR Lens Discussion 8 10-16-2010 06:30 PM
Quick question: what is that? future_retro Video Recording and Processing 8 09-19-2010 12:32 PM
K-X Quick Question NecroticSoldier Pentax DSLR Discussion 6 03-01-2010 02:11 PM
Quick Question jct us101 Film SLRs and Compact Film Cameras 2 07-08-2009 02:15 PM
just a quick question little laker Site Suggestions and Help 5 09-12-2006 06:32 PM
All times are GMT -7. The time now is 09:49 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
