02-17-2011, 05:45 PM   #1
Problem with MZ-7
Just picked up a SMC Pentax -A 50mm 1.7 and can't figure out how to make it work on MZ-7
mount looks a bit different and there aren't any connectors to make it work if full auto
02-17-2011, 06:48 PM   #2
Ole
Ole's Avatar
The mount is fine, it is a KA mount, and the lens should work. At '180 degrees' in your photo you can see the pin that signals when the aperture ring is set to "A", and a bit further to the left is an insulator (or a cutout - works the same) which signals the aperture range.
You can read about your camera here:
https://www.pentaxforums.com/forums/pentax-autofocus-film-slr-camera-reviews/...-7-zx-7-a.html
02-17-2011, 07:18 PM   #3
So... if I understand correctly this lens will work only in Manual Mode and AV Mode?
Do I need to keep aperture ring on "A" setting to work in AV mode, or should I dial it down to the 1.7 setting?
Thanks
02-17-2011, 08:00 PM   #4
Ole
Ole's Avatar
The camera will work in all exposure modes with this lens at the "A" setting. You can leave the aperture ring at the "A" position and control everything, including the aperture from the camera.
Optionally you can set the desired aperture on the aperture ring. The MZ-7 is quite advanced and can work both ways:
02-17-2011, 08:18 PM   #5
Ole
Ole's Avatar
You can find the MZ-7 operating manual here:
Pentax Canada | Operating Manuals for Pentax Cameras
02-17-2011, 08:21 PM   #6
Thank you, very much
mz-7
K-5 battery problem? camera problem? user problem? imtheguy Pentax K-5 39 11-03-2010 06:02 PM
Card read problem K20d. Have you had this problem? rsi1986 Pentax DSLR Discussion 8 12-27-2008 05:25 AM
Problem with my ZX-50 midwest 1953 Pentax Film SLR Discussion 2 05-25-2008 06:51 AM
this may be a problem nathancombs Pentax DSLR Discussion 24 02-02-2008 10:39 PM
Am I alone or are there others who had this problem too ? ABCWinter Digital Processing, Software, and Printing 4 01-21-2008 11:16 PM
All times are GMT -7. The time now is 09:18 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
