03-08-2011, 09:11 PM   #1
GerryL's Avatar
Fixing ZX-5n
Ok, so I have already dismantled the camera and already replaced the motor.
My question is with regards to the mirror.
Does the shutter mirror stay normally in the up position?
Does the mirror have to be down when the new motor is replaced?
When I reassemble with the mirror in the up position, will the mirror stay down once I have replaced the motor and cycled the camera?
Once I'm sure with this, I can finally reassemble the camera.
I don't want to assemble then find out that I have to disassemble again if the mirror has to be in the down postion.
I hope somebody can help!
03-08-2011, 10:04 PM   #2
There are 3 electric contacts on the green gear; the green and yellow are synchronized by line up the holes together (i.e. the relative cam positions on the back sides of these 2 gears). Before closing the gear box cover, mirror is up, diaphragm control slider is at top edge, all the center axles are flash, tighten the 4 screws. I usually rotate the first speed reduction gear for one cycle to make sure the gears operate correctly. After this, you can leave the mirror in any position. After complete assembly, install the batteries, the firm ware will move the mirror to where it should be, you don't even need to turn the switch on.
After the mirror box is in place. Install VF eyepiece and operate panorama switch to make sure it works. This should be done before re-solder the wires.
03-08-2011, 10:41 PM   #3
GerryL's Avatar
Thanks David!
I will have to resume tomorrow now that I know what I have to do.
I just need to close up and test the thing.
Will update on this..thanks again!
camera, mirror, motor, position
Fixing the flash on Z-1p? phosphoro Pentax Film SLR Discussion 9 01-01-2011 09:02 PM
PP for Fixing Exposure Dubesor Video and Pentax HDSLRs 7 08-27-2010 03:30 AM
Fixing her hair mr tibbs Monthly Photo Contests 0 01-09-2010 08:33 PM
Fixing a negative jzietman Digital Processing, Software, and Printing 33 10-21-2009 01:26 PM
fixing signature oatman911 Site Suggestions and Help 3 06-25-2009 09:00 AM
All times are GMT -7. The time now is 05:05 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
