03-16-2011, 03:57 PM   #1
Need help! Super Program's NOT working shutter control.
I have an old Pentax Super Program.
Recently my friend borrowed this for her photography class.
Right now, I can't get to change the shutter speed anymore when switched to M mode.
Somehow, the top LCD display only show 1000 (sometimes) or nothing at all.
It's not dead yet because it still show 125x or B when I switch to those modes.
I've tried to take off the lens (A 50mm 1.7) and re-mount it again but it doesn't do anything.
It worked for a few second where I can adjust the shutter speed and see the exposures compensation through the viewfinder lcd but then it went dead again.
Now it doesn't show anything anymore.
Anybody can please give me advice on how to fix this problem?
Is my Super Program totally broken?
I really hope I can fix it myself.
Thanks in advance.
03-16-2011, 03:59 PM   #2
boriscleto's Avatar
Have you tried fresh batteries? The Super Program doesn't function at all without batteries.
03-16-2011, 04:04 PM   #3
Is film loaded? Perhaps you pushed the button on bottom accidentally. Fire three blank shots and it should continue working again.
03-16-2011, 04:09 PM   #4
QuoteOriginally posted by boriscleto Quote
QuoteOriginally posted by elho_cid Quote
Hmm..good suggestions. I haven't changed the battery since my friend borrowed it.
Elho_cid, I'll try this when I get home tonight.
Thanks, guys. Hopefully it will come back alive again.
03-16-2011, 05:55 PM   #5
GerryL's Avatar
I agree with this, wind and fire the camera until it reaches counter "1" or "0" (I forgot) because, the super program/super-A stays at the speed of "1000" so that it will easily reach the first frame and not "meter" before the first frame.
Reasoning behind this is, if it "meters" immediately and you have the cap on the lens or it is dim, then the shutter wouldn't be as fast and going into the first frame to set up for your first shot would take a longer time rather than just firing 3 fast (blank) shots.
"B" (bulb) setting wouldn't also work if camera lens is set to "A", as I recall, the aperture lens should be opened and not locked to "A".
03-16-2011, 08:52 PM   #6
Problem solved.
After I wind & fire until the counter reaches 1, I can adjust the shutter speed again.
Thank you for the helps, guys.
03-18-2012, 08:52 PM   #7
Awesome, so glad to find this info. I was about to pull my hair out! I even signed up and was about to pose this same question before a quick search found the answer.
I had searched the interwebs far and wide for an answer to this issue - and some of the results even led me to this site, though not this particular post. That said, I'll throw a few keywords in for good measure so that the next person with this issue won't have to search so hard:
Pentax Super Program shutter speed problem
Pentax Super Program shutter speed stuck at 1000
Cannot change shutter speed on Pentax Super Program
I'll be posting some pics soon from my pristine new (old) Pentax!
lcd, program, shutter
Remote Shutter Control KidLogic Pentax DSLR Discussion 8 11-30-2010 07:59 AM
remote control not working geckogrin Pentax DSLR Discussion 5 09-22-2010 07:40 PM
Help! MZ-7 shutter release not working Black Magic Pentax Film SLR Discussion 9 08-12-2009 08:56 AM
P30T, shutter will not reliably stay open on bulb with cable shutter control. skid2964 Pentax Film SLR Discussion 6 06-09-2008 08:04 AM
All times are GMT -7. The time now is 01:15 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
