04-12-2011, 03:09 PM   #106
GerryL's Avatar
QuoteOriginally posted by pbo Quote
Yashica winding is very very smooth, actually, I was a bit skeptical sometimes whether I managed to load the film correctly because it was so smooth (I did load correctly, the rewind handle was rotating when advancing film). The camera thumps in the beginning of the winding action, and the thump doesn't really affect anything much - it's pretty quiet.
Yeah, seller mentioned that it had something to do with the seals if I recall right.
If it doesn't produce a thump, then one of the inside seals had gone bad, I dunno how true this is.
04-12-2011, 03:24 PM   #107
pbo
pbo's Avatar
That issue is called "pad of death".
04-12-2011, 03:34 PM   #108
GerryL's Avatar
Oh yeah, now I recall what it is!
So, does this occur often?
How does one go about buying a Yashica RF with this being ok?
Any tips?
04-12-2011, 04:50 PM   #109
ChrisPlatt's Avatar
As linked early in the thread by Paul the Compact Rangefinders of the 1970's
pages on Stephen Gandy's Cameraquest website have a wealth of information
on most of the cameras already mentioned here, plus many more.
Another great resource is Rangefinder Forum: http://www.rangefinderforum.com
Chris
04-12-2011, 08:02 PM   #110
QuoteOriginally posted by ChrisPlatt Quote
Chris
I re-read that article today! It should be noted that the prices of most of his "favs" have gone through the roof. I was thinking that an Olympus 35 RD might round out the rangefinder harem nicely. Think again, Steve! No way am I going to pay what the current eBay crop is going for!
04-13-2011, 03:29 AM   #111
Nesster's Avatar
you also might take a look here:
View Forum - Best of Fixed Lens Cameras Gallery::Manual Focus Lenses
there's some samples from fixed lens range finders
I have done a comparison of the GSN vs Konica Auto S2, I forget where I posted it. Essentially I think the lenses are equal, but the Konica has better material feel, the light meter is in the lens (so you get filter factors built in), has manual exposure capability... The two downsides are that I need 2 stops ISO bias with modern batteries (i.e. I shoot ASA 400 at 100 on the meter) which can be a boon as this expands the upper limit ISO; and that it is a shutter preferred automatic, which I'm not so used to.
But then, I'm sure the contemporary Minoltas and Canons each have their positives... I'd just jump in if I were you, these are cheap enough to try out and learn what you like/don't like.
As I say, the mercury battery thing can be safely bypassed: and there's a benefit as the upper end of the ISO range expands when you bias the meter down.
04-13-2011, 04:42 AM   #112
Aristophanes's Avatar
The Oly 35 RD is problematic because they will all leak oil on the shutter blades and require a full rebuild @$$$$. If you are OK with simple cheap auto the Trip 35 is the all-time cult classic RF.
04-13-2011, 05:28 PM   #113
ChrisPlatt's Avatar
Used RF camera buying tips
I was bitten by the rangefinder bug many years ago.
Like used SLRs, finding a good used rangefinder camera can be challenging.
I have purchased many RF cameras on eBay. Some were good; many were bad.
Often eBay sellers claim they are unable to check the light meter due to a dead battery etc.
If so chances are the meter does not work. If repairable getting it fixed is never cheap.
Without a working meter do not expect autoexposure or electronic shutter (if so equipped) to function.
At minimum expect bad light seals which must be replaced.
More often than not shutters require cleaning and speeds adjusted.
The rangefinder focusing mechanism may be misaligned and require adjustment.
If the patch is difficult to see often no economical repair is possible.
Most of these older cameras were designed to use 1.3V mercury batteries, now unavailable.
There are various workarounds to this issue.
Good luck!
Chris
04-13-2011, 06:22 PM   #114
QuoteOriginally posted by Aristophanes Quote
I had Trip 35 years ago. It was a fairly good camera but I don't recall it having a rangefinder ? Maybe justtoo long ago to remember.
Eric
04-13-2011, 07:08 PM   #115
Nando's Avatar
QuoteOriginally posted by erkie Quote
Eric
The Olympus Trip 35 is not a rangefinder. The Contax G and Rollei 35 mentioned earlier in this thread also aren't rangefinders.
04-14-2011, 12:33 AM   #116
ChrisPlatt's Avatar
The extremely short base rangefinder on most compacts is not very precise.
Depth of field carries the day.
Zone or scale focus is perfectly fine for models equipped with a 40mm or wider lens.
As a bonus there is no delicate rangefinder to become misaligned or break.
Chris
04-14-2011, 05:49 AM   #117
GeneV's Avatar
I found an XA for a good price at a local camera store, and took it out for some test shots yesterday. After using the XA2 for a while, it was odd to fiddle with the focus at the bottom again, and to have the aperture where the focus is on the XA2. However, I noticed once again how many shots with the rangefinder ended up at infinity, which seems to start effectively at around 20 feet with this finder. Once you get past 12 feet or so, the focus movements on that little tab are minute. As Chris says, depth of field carries the day and, to me, that also means higher ISO is my friend.
04-14-2011, 06:27 AM   #118
eddie1960's Avatar
QuoteOriginally posted by GeneV Quote
And these cameras are generally used in situations where both the zone focus and higher iso aren't issues in any case. stick it in your pocket and go. if you are chasing amazing landscapes or portraits or anything requiring precise focus and dof you'll likely carry the slr in any case (or a more sophisticated much more expensive RF)
04-14-2011, 06:29 AM   #119
GeneV's Avatar
QuoteOriginally posted by eddie1960 Quote
Absolutely. Not too many close portraits are taken with a 35mm lens on 135.
04-14-2011, 06:45 AM   #120
eddie1960's Avatar
Not complimentary ones in any case
camera, rangefinder
Rangefinder camera repairs? ChrisPlatt Non-Pentax Cameras: Canon, Nikon, etc. 4 08-09-2010 05:03 PM
For Sale - Sold: Zorki-5 Rangefinder Camera (re-badged Leica) with Two Lenses yb_abq Sold Items 3 09-03-2009 06:45 PM
What you care more on shopping digital camera, good quality or or good looking? emilyy General Talk 19 12-12-2008 07:35 PM
All times are GMT -7. The time now is 07:18 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
