04-27-2011, 03:34 AM   #1
MZ-M (ZX-M) very premature rewind
I have just given an old MZ-M to a friend and typically he has immediately got a problem I don't remember seeing before.
Before I gave it to him I just finished up an ancient film in it. I rewound fine. I told him I didn't know the state of the battery, so he has replaced it.
On loading a film (I wasn't there, so I don't know if he did anything wrong) it wound on to "1" then immediately rewound.
Any ideas whether it might be user error (what could it be) or a problem with the camera?
Thanks
04-29-2011, 03:07 AM   #2
Happen twice in app. 14 years of use with mine Simon.Had CR2 lithiums installed.
Has never happened since I picked up battery grip (FG) and used with required AA
cells(4),either alkaline or lithium.Assumed CR2's were in fully charged state when
bought,didnt verify..Did try to 'dig' leader out of canister to try and re-shoot
wasnt able to grab either without damage.Film is still a little suspect, though
it hasnt happened again since BG(FG) was added.
05-03-2011, 08:19 AM   #3
Thanks BillM.
Since my original post I've got my last film back from the camera (before I gave it away) and found that the last few frames suffered a wind-on problem - they overlap slightly. I guess either:
- The film had got sticky having been in the camera for some time,
- The camera wind-on had got a bit sticky, which may or may not sort itself out (or need a service) or
- The wind cog had (as sometimes reported) got brittle and failed when I took the camera out of "moth balls"
I will see how my friend got on with a second attempt to load the camera, and maybe recommend a service - which might not be economic on a camera I just gave him (he's on a fairly tight budget).
Thanks
Simon
film, mz-m, rewound
Rewind Shaft EricTn Pentax Film SLR Discussion 4 11-07-2010 04:41 PM
Missing lever on MX rewind knob QuixoticTonic Pentax Film SLR Discussion 6 01-16-2010 01:41 AM
Film rewind problem MeFirstO Pentax Film SLR Discussion 17 07-15-2009 11:26 PM
Help! Spotmatic rewind trigger stuck! drewdlephone Pentax Film SLR Discussion 4 06-23-2009 06:13 PM
K100 has premature 'Low Battery Indication/ shut down" seriousam Pentax DSLR Discussion 19 07-09-2007 08:36 AM
All times are GMT -7. The time now is 04:18 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
