05-05-2011, 08:30 AM   #1
ghl's Avatar
A K2 question
I'm considering buying a K2 mainly to have mirror lockup on a film body. I will initially be using M42 lenses on it until I get some M or A lenses. The question I have concerns the aperture priority metering of the K2.
Does the K2 aperture priority (automatic mode) metering rely on the aperture position cam of Kmount lenses in selecting the shutter speed? In other words, will the K2 only be a fully manual stopped down metering camera with an m42 lens mounted or will the aperture priority metering still work with the M42 lens on manual and stopped down to the shooting aperture?
Thanks!
05-05-2011, 10:12 AM   #2
gofour3's Avatar
QuoteOriginally posted by ghl Quote
Thanks!
I don’t have any M42 lenses, but I do have some manual diaphragm lenses which require stop-down metering.
This is how it should work on the K2:
1) Set the K2 shutter speed to Automatic.
2) Set attached lens to the maximum aperture.
3) Compose shot.
4) Set lens to the desired aperture that you want for the shot.
5) Press the shutter.
Phil.
05-05-2011, 11:18 PM   #3
Add an additional step to Phil's explanation for M42 lenses:
0) Flip A/M switch on lens to the M position...
K and M lenses will work in both Av and M modes. A-series and newer require an aperture ring set in other than in the "A" position.
The manual contains full information on all of the K2's features and may be downloaded from Pentax USA or from the Butkus site:
Pentax K 2 instruction manual, user manual, PDF manual, free manuals
05-06-2011, 12:56 AM   #4
ghl
ghl's Avatar
Thanks for the help! Seems it should be no problem for Av mode with an M42 lens.
Cheers!
05-08-2011, 04:43 AM   #5
Blue's Avatar
The K2 is one of the better k-mount film bodies Pentax ever built. It is kind of like the ES I or II with a metal shutter and k-mount. It was the fruition of the Metallica II prototype that Pentax unveiled in 1966.
05-08-2011, 04:45 AM   #6
Blue's Avatar
Cheers!
The m42 lenses need to be operated in the m position and will use stop down metering rather than open aperture metering.
05-08-2011, 10:17 AM   #7
Kim C's Avatar
Alternatively, if you want to download the manual with slightly better scans, try my website here
Pentax Manuals
Kim
aperture, k2, lens, lenses, m42, priority, question
K-x AF Question benjikan Pentax DSLR Discussion 16 04-07-2010 10:41 PM
FA 28-70/f4 question TTQ225 Pentax SLR Lens Discussion 6 11-29-2009 03:23 AM
K7 question dafiryde Pentax SLR Lens Discussion 12 08-14-2009 10:18 AM
K7 question dafiryde Pentax DSLR Discussion 5 07-17-2009 06:05 PM
Question about K20D ddjchemist Pentax DSLR Discussion 9 05-14-2009 07:23 PM
All times are GMT -7. The time now is 09:37 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
