05-31-2011, 08:37 PM   #1
Clinton's Avatar
ZX-5n wont soot?
I've recently come to possess a ZX-5n that seems to be broken.
When I press the shutter button, I hear a high pitched wine, but no mirror slap and no shutter sound.
I've tried new batteries and no luck. Is this something I can try to unjam myself? If not, I suspect this film body is going to end up in the trash heap.
05-31-2011, 08:50 PM   #2
Have you got a lens on the camera? What is the Auto Focus set to? Was there film in the camera? If there is, is it trying to load the film?
More info needed.
Regards
Chris
05-31-2011, 08:51 PM   #3
Probably a stripped motor gear - see this thread.
06-01-2011, 04:54 AM   #4
Clinton's Avatar
QuoteOriginally posted by seventhdr Quote
It did load the film just fine. Whirred and buzzed and loaded it up.
I've mounted the FA* 80-200 on the camera for testing. It auto-focuses fine, but it just wont shoot the picture. It just whines while I press the shutter button and then stops. No film advance, no shutter sound of any kind.
06-01-2011, 04:55 AM   #5
Clinton's Avatar
QuoteOriginally posted by gabriel_bc Quote
It doesn't sound like the motor is turning, it sounds more like it's under load but unable to turn.
06-04-2011, 04:18 PM   #6
GerryL's Avatar
Same guess here since these cameras are prone to this.
I am currently repairing one but I accidentally tore one of the flex wiring so I had to bypass those with wires or get another one for parts or repair and cannibalize the part that I need.
For now, I just jumped the connections with regular wires.
06-04-2011, 06:06 PM   #7
frank's Avatar
It's a very common problem for MZ series cameras (except MZ-S?). The plastic gear which hooks hup the motor and mirror is cracked. You need to eaither change the plastic gear or better just change the whole motor (with a brass gear). You can still find this motor on ebay.
shutter, zx-5n
K-7 wont update MrHowell Pentax DSLR Discussion 3 01-17-2011 02:06 PM
Optio E85 wont turn on figgy67 Pentax Compact Cameras 2 11-27-2010 04:11 PM
Why wont my lens work for my k2000 pgfilms Troubleshooting and Beginner Help 2 11-18-2010 07:46 PM
K7 wont take pictures in dark?? XeroX Pentax DSLR Discussion 14 08-03-2010 04:41 PM
Some of you wont like these.....Araneus!! Rense Post Your Photos! 11 08-10-2009 11:04 AM
All times are GMT -7. The time now is 12:11 PM. | See also: NikonForums.com, part of our network of photo forums!
