08-02-2011, 02:22 PM   #16
QuoteOriginally posted by Macario Quote
With the MZ-S you actually cannot control it directly, you can only use Tv mode, and then control the aaperture through the Tv
Hyper-manual?
Again...Tv mode is not that bad a compromise as long as the camera displays the computed aperture. The process is strictly analogous to using an older film camera without exposure automation such my KX, Singlex TLS, and 1000 DTL. The general flow with those cameras is to select a shutter speed and dial in the aperture until the needle centers. (Few are the cameras with shutter speed dials that are easily settable with the camera at the eye.) Simply set the shutter speed and let the camera do the work. Change the shutter speed if needed.
08-02-2011, 02:32 PM   #17
dgaies's Avatar
Peter, as far as I can tell the DA*55 works fine on the ZX-L in Av mode. Obviously no AF, but it appears to cover the whole frame from what I can see in the VF.
08-02-2011, 02:33 PM   #18
derelict's Avatar
I can control aperture on my ZX30 and my P30T, for what its worth.
08-03-2011, 11:04 AM   #19
Hyper-manual?
but the thing with controling the aperture with Tv is that when the camera detects a different level of lights, your aperture will change.
08-03-2011, 12:25 PM   #20
My Pentax ZX-60 is 100% functional with all of my DA* lenses (sans autofocus, of course). You get some cool vignettes with the ones that don't cover the whole frame.
08-03-2011, 01:41 PM   #21
My PZ-1 works like my K20D in Hyper Program mode; the rear dial changes aperture value and the front dial changes the shutter speed. When an A lens is mounted, it works as any A lens does with Pentax DSLRs; AE without AF. When an M lens is mounted, there is no aperture value showing up inside the viewfinder but physically turning the aperture ring causes corresponding change to the shutter speed while the viewfinder remain bright. PZ-1 is pre PKAF2 the crippled mount (no annoying green button metering). an m42 lens with an adapter works the same as DSLRs; stopped down metering in Av mode (camera defaults to Av mode).
Hope this helps,
08-03-2011, 02:15 PM - 1 Like   #22
RioRico's Avatar
My bleary eyes read the subject as ACUPUNCTURE CONTROLLING BODIES and I thought of pins and needles. Ouch.
08-03-2011, 02:30 PM   #23
Direct control of aperture from the body started already with the S/SF series (one series before the Z/ZX). At least the top models provide a "wheel" (actually it looks like a switch, but functions the same way as a wheel), which can be used without taking your eyes from the viewer
I own a SFXn, and in P, Av, and M mode you can "dial" through the aperture values.
I also own a Z20, an there it is roughly the same.
08-03-2011, 06:34 PM   #24
Steve Beswick's Avatar
QuoteOriginally posted by derelict Quote
Not with the P30t. Not possible.
08-03-2011, 06:37 PM   #25
The ZX-7 does what you want, only with a "paddle" to change the setting, instead of a control wheel. Also, a manual focus screen from a ZX-M drops right in. Once you become accustomed to the paddle thingy it actually works pretty well.
08-04-2011, 03:23 AM   #26
Lowell Goudge's Avatar
QuoteOriginally posted by axl Quote
thanks all for the replies. I am indeed looking for film camera that can use Av mode. I have DA*55 which supposedly covers 135 frame but lacks aperture ring. So I'd love to be able to use normal Av mode with e-dial. Unfortunately Z/PZ bodies were not on top of my list but it seems they might be the best option... and if they can handle AF500FTZ that would be added bonus...
PZ-1 and PZ-1p can do all you describe/ask and much much more.
it is a big camera though. Fullsized film body but a very good camera. I don't use mine often enough, but I do shoot with it at least once or twice a year. Last time was 4 rolls of ISO 3200 B&W film
08-05-2011, 03:43 AM   #27
Yes SF-1 is able to control aperture via the non rotating fake wheel. Its cheap and nicely shaped if you prefer the shape of dslrs to traditional slrs. Come to think of it , It's better than my Kx, the shutter button falls in a more comfortable position . I know i'm not supposed to, But I do like this one. But it AIN'T no compact !
Eric
08-05-2011, 11:55 AM   #28
Feel whats been mentioned regarding A series bodies forward,correct.
Although it seems on some,pentax engineering controls apeture and user
gets to stand by and watch.(P3n,P5 in my experience)
ZX-L(s) owned go the 'whole nine yards'
08-09-2011, 11:05 AM   #29
How come the Z/PZ bodies were not on top of your list. I have the Z-20, and think it is a great camera. Not too big, and you can control the aperture through the body
05-13-2012, 08:36 PM   #30
Thanks to the OP for making this thread! On the KMP site it says that the MZ-3 has Av mode - therefore, you can control aperture in-body, right? I'm looking to buy this one at a local secondhand shop (needs some repair with the mirror though). Doesn't have to have control wheels, buttons will do as long as I can use my DA 35 with it (which is largely said to be FF-compliant also).
I would recommend the Z-1P though it's really big. I've seen an SFX/SF1 alongside the MZ-3 I'm planning to buy and they can control aperture directly from the body via buttons (tested it, so I can guarantee). Prob with the SF1 though is the battery - 2CR5's aren't very common in stores nowadays (or at least in my country maybe)
aperture
Controlling Aperture on an FA Lens Question justtakingpics Pentax SLR Lens Discussion 2 03-25-2011 01:05 PM
controlling 2 (or 3) flashes on the cheap slip Flashes, Lighting, and Studio 22 02-06-2011 12:39 PM
Variable aperture, M-series film bodies question Cinders Pentax Film SLR Discussion 7 01-27-2011 02:53 PM
Controlling Aperture with DoF Preview Button? Hello_Photo Pentax Film SLR Discussion 2 09-04-2010 01:16 PM
Kx (or K7) Controlling shutter speed? Coby Video and Pentax HDSLRs 28 01-06-2010 05:20 AM
All times are GMT -7. The time now is 03:48 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
