08-25-2011, 09:10 PM   #1
MarieDJ
Guest
Pentax MX with M42 Adapter - Cannot fit 21mm lens
Hello everyone!
I have an MX fitted with a genuine pentax M42 adapter to use those great takumar lenses. However, I just acquired a Mamiya Sekor 21mm lens that will not screw in all the way...and I am unsure as to why. Any help would be greatly appreciated.
08-26-2011, 01:10 AM   #2
titrisol's Avatar
Location: In the most populated state... state of denial
I saw your photo on flickr.
If you have a screw mount camera test the lens there; maybe the threads were damaged at some point.
Otherwise, some Mamiya lenses used to sit at an angle compared to takumars.
08-26-2011, 06:58 AM   #3
Wheatfield's Avatar
There may be a small pin sticking out of the back of the lens that is fouling the mount. I recall a customer of mine having this problem with a Mamiya lens.
08-26-2011, 07:53 AM   #4
MarieDJ
Guest
I will test it out - my Spotmatics are currently in Eric Hendrickson's hands getting a much needed overhaul. As soon as I get them back I will see.
08-26-2011, 09:03 AM   #5
Otis Memorial Pentaxian
What series Mamiya Sekor lens is it? The SX series M42 lenses had extra coupling hardware that may be the source of the problem.
08-26-2011, 11:41 AM   #6
MarieDJ
Guest
The lens does say SX - I am attaching some pics...
08-26-2011, 02:14 PM   #7
titrisol's Avatar
looks very good!!
However the rear element seems to be quite large and may touch the mirror and thus prevent it from screwing in
just a hunch... can you try it in the adaptor out of the camera
08-26-2011, 03:55 PM   #8
QuoteOriginally posted by MarieDJ Quote
See the pin on the left? That is probably your problem. As suggested above, you might try putting the adapter on the lens off-camera as a test.
You might also try Google since this is a known compatability issue with the SX lenses on non-SX compatible bodies. Here is a link to a page that details the surgery to make your lens usable with other than SX cameras:
Mamiya Sx lens auto diaphragm pin modification and adapting.
08-27-2011, 05:32 AM   #9
MarieDJ
Guest
Thank you for the link. I had no idea what I was getting myself into when purchasing this lens! I am not too much of a handy person when it comes to DIY, but do you think Eric Hendrickson might be able to mod it for me? I will ask him, but just wondering if he does that normally?
Thank you so much for resolving this issue. At least I know what was causing the issue.
08-27-2011, 06:13 AM   #10
Blue's Avatar
Given the quirkiness of the SX series lenses, they are still excellent performers. As far as Eric modifying it for you, email him along with the above pic. I suspect he would. He also needs to deal with the aperture pin in addition to the other pin because it doesn't have an A-M switch which means it is in Auto all the time. It will need to be in manual to use on K-mount film and digital bodies. That over hang the aperture ring does has given me problems before on The Sekor 28mm SX.
21mm, adapter, lens, m42, m42 adapter, mx, pentax, pentax mx
Pentax Lens will not fit into m42 adapter! Please help! alfie_mint Pentax SLR Lens Discussion 13 08-14-2011 01:04 PM
Do all Pentax lenses fit the K 7 without any kind of adapter ? Adk X Pentax SLR Lens Discussion 6 01-26-2011 08:12 PM
For Sale - Sold: Pentax m42 lens to k-mount camera adapter (Worldwide) jgmankos Sold Items 4 07-28-2010 09:33 PM
For Sale - Sold: Industar 50-2 50mm f/3.5 Soviet M42 lens + M42 Adapter 65535 Sold Items 10 11-27-2009 04:18 PM
Adapter to fit canon lens on pentax? ronald_durst Pentax SLR Lens Discussion 7 08-11-2007 10:50 AM
All times are GMT -7. The time now is 12:26 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
