Originally posted by womble I used mine in manual for 15 years or so. I found the Av mode wasn't accurate enough when shooting slides (mainly Kodachrome 64).
It would expose for the sky leaving the buildings (or whatever) about a stop or so under-exposed which with slides is not good.
Mind you, it isn't that the ME Super was bad in that respect, most cameras I have used are similar.
Some Pentax models include
AE lock, a powerful feature when used with the technique known as
substitute metering.
In AE simply point camera at a scene that indicates your preferred exposure; activate AE lock; recompose and shoot.
In the example you give this would mean simply pointing it down slightly to include less sky.
Since you never need remove your eye from the viewfinder, with practice this is much faster
(and much easier) than switching to manual or fiddling with the exposure compensation dial.
Chris
