12-03-2007, 01:17 PM   #1
Battery Problem, KX
Hi.
Iwe got a Pentax KX and today I was trying to change from depleted batteries to new fresh ones. Before the change the batterytester worked etc but now it wont budge. It wont move even if I use fresh new batteries.
What can be the problem? Any corrotion on the surfaces maby? It was a time sins this camera where used.
//Wompa
12-03-2007, 04:28 PM   #2
Bryce's Avatar
My KX suffered a similar problem recently. I couldn't find any corrosion, so took it to the repairman. He ended up finding corrosion somewhere in the battery compartment, said it looked insignificant but made all the difference.
Unfortunately I don't know exactly what he did, so can't tell you where to scrape the contacts.
Hopefully yours is as easily repaired!
12-03-2007, 04:54 PM   #3
Canada_Rockies's Avatar
QuoteOriginally posted by Wompa Quote
Hi.
Iwe got a Pentax KX and today I was trying to change from depleted batteries to new fresh ones. Before the change the batterytester worked etc but now it wotn budge. I wont move even if I used new batteries.
What can be the problem? Any corotion on the surfaces maby? It was a time sins this camera where used.
//Wompa
Use a pencil eraser on the contacts (not the ink one - it scratches too much). Don't forget the cover!
12-03-2007, 08:41 PM   #4
raymeedc's Avatar
Before you do anything, I would try different batteries, as they've been known to to be dead-on arrival, even when new..... happened to me a couple of times.
12-04-2007, 03:22 PM   #5
So, first I get some new batteries, but it feels odd when I just bought some.
And then I can test the pencil trick. See if it works and maby I dont need to find a camerarepairer for my camera. But im not sure if my town got one. I will look around alittle.
Thanks for the tips! Real great!
batteries, change, kx
K-5 battery problem? camera problem? user problem? imtheguy Pentax K-5 39 11-03-2010 06:02 PM
Battery problem?? timstone Pentax DSLR Discussion 19 04-11-2010 06:28 AM
Yet Another K-x Battery Problem Deniz Pentax DSLR Discussion 16 04-08-2010 02:55 PM
Battery problem in a Km mvecchi Pentax DSLR Discussion 0 01-10-2010 03:33 PM
Second K-x in a week with battery problem wll Pentax DSLR Discussion 30 12-12-2009 11:12 AM
All times are GMT -7. The time now is 02:38 PM. | See also: NikonForums.com, part of our network of photo forums!
